Jarmo showed me my first Vmod ever on the ASUS A7M266.Originally posted by OneProdigy
Finally here it is!
location of the W83301R regulator
affected pins
added resistors (or pots)
If you have a look at the pics there are 2 resistors (R1, R2) added to pin 19 of the W83301R regulator.
(R1+R2)/R2 should give new voltage. If R1 = 10 ohms and R2 = 100 ohms then it should give 10% increase and 1.1 x 2.5V = 2.75V and 1.1 x 2.7V = 2.97V!
If you decide to use R1 = 20 Ohms and R2 = 100 Ohms, you'll get 1.2 x 2.7V = 3.24V which should be sufficient for extreme memory overclocking.
Like DDTUNG mentioned before this mod includes cutting pin 19 of the W83301R regulator!
Most sure way to do the mod is connecting resistors directly to the W83301R chip's leg no 19. Desolder leg from the mobo (heat with solderingiron and pry it up with needle or something).
Look where the trace is going and solder 10 ohms resistor from original trace to the chip's leg. 100 ohms resistor goes from chip's leg to ground (pin 5 or similar).
The credits for this mod go to Jarmo Pirinen who did a great job helping me to figure out how this mod is to be done! Thanx again, Jarmo!
Be aware that like any other modification to hardware you'll loose waranty if doing this mod!
Furthermore i'm not responsible for any damage this mod might cause to your hardware!
I didn't have time to mod my BD7-II Raid yet, but i'm pretty sure it'll work - but it's still untested!
This post is for any of you who can't wait till i modded my board to validate this mod is working properly.
Good luck!
DDTUNG
