+ Reply to Thread
Results 1 to 3 of 3
Thread: 2GB OCZ FlexXLC PC2-6400 -- $224 AR @ Newegg
    Xtreme Enthusiast 5-Clicks's Avatar
    Apr 2005
    Atlanta, GA
    0
    http://www.newegg.com/Product/Produc...82E16820227185
    Here's for all those water cooling owners. The only downer is that the elbows in the loop will kink the water flow a bit.
    Intel C2D E6600 (L630B015)
    TT BigTyphoon || Zalman VF900 Fatal1ty
    Abit QuadGT
    2GB Corsair Dominator PC2-8500
    HIS X1900XT --> XTX
    Creative X-Fi Elite Pro
    OCZ GameXStream 700w
    Feedback:
    HEAT --- eBAY
    Xtreme Member cursivearmy1's Avatar
    Sep 2006
    Hauppauge, NY
    0
    Quote Originally Posted by somguyneweggreviewermanperson
    Cons: Very tall, may interfere with some aftermarket CPU coolers. Most boards will default the write to precharge at 10, needs to be changed manually to 11 for highpeed stability
    thx for the heads up but why would someone have a aircooled CPU and watercooled ram?
    Abit Fatal1ty F-I90HD mATX w/ HDMI
    Intel Core 2 Quad Q6600 SLACR/G0
    Buffalo Firestix 2x1GB DDR2-1000
    Razer Barracuda AC-1
    Apevia X-Qpack2 Black & 420w PSU
    Stock Intel HS w/ 92mm fan
    Xtreme Addict m0da's Avatar
    Jul 2005
    ATX
    0
    Quote Originally Posted by 5-Clicks
    aimed at those with water, so water + water =
+ Reply to Thread
