+ Reply to Thread
Results 1 to 5 of 5
Thread: UV Additive losing its UV properties over 10 days?
    Dec 2006
    Athens, Greece
    0
    Is this normal? I added UV liquid to a loop just to test it and aftger 10 days the water does not glow anymore? I am also using silver in the loop could this be the cause? Anyone had this happened to him?
    Hardware :Asus Rampage Extreme, 4870X2 (Crossfire X) EK FC Blocks, CPU Q9550@490FSB/4,180Ghz, RAM 4GB DDR3, Auzentech Prelude X-fi,PSU - Thermaltake Toughpower 1200 Watt,
    3 Loops with TFCs360 and a PA.120.2/DDCs.
    Dec 2006
    Newark, CA
    0
    If I were a bettin' man, I bet that you were using Fluid XP...Am I right?
    http://www.xtremesystems.org/forums/...ighlight=fluid
    I'm using the blue Pentosin G11 from Petra's and it's not UV reactive so I added the following...
    http://www.performance-pcs.com/catal...oducts_id=2740
    I'm still getting the UV reaction even after nearly a month of use...
    Dec 2006
    Athens, Greece
    0
    Well I am not using Fluid XP - Only pharmaceutical water (WFI - water for injection) and silver wire for algae. That is all no other additive!
    Registered User JamesTX10's Avatar
    Dec 2006
    Dallas, TX USA
    0
    what UV additive are you using?
    My New Rig My OLD Rig
    Case: Mountain Mods - U2-UFO Horizon Black Powder Coat - Original Top
    Power Supply: Enermax Galaxy Gaming Edition 1000W Power Supply EGA1000EWL-DXX
    Motherboard: EVGA NVIDIA nForce 680i SLI ATX
    CPU: Intel Core 2 Extreme QX6700 Kentsfield 2.66GHz
    Ram: Dominator 4GB (4 x 1GB) DDR2 1066 (PC2 8500)
    CD / DVD burner: Plextor PX-755SA internal Serial ATA
    Hard Drives: SeaGate HD 250Gig 7K 8M SATA2 ST3250824AS / SeaGate HD 500Gig 7K 16M SATA2 ST3500630AS
    Water Cooling: Swiftech H20-220 Apex Ultra CPU Liquid Cooling Kit / EK NF4 On the SB / DD-680i Chipset Block / 2 - Danger Den Delrin Fillport / DD-D5 Pump / 7/16" ID (5/8" OD) Masterkleer / PA120.3 with shroud
    Fan Controller: Sunbeam 5.25" Chromatic Windmill Full Function Fan Controller – Black
    Fans: 2-120MM Aerocool XtremeTurbine – Silver / 2-Thermaltake A2018 120mm Blue LED / 4-SCYTHE S-FLEX™ 120mm
    Misc: 4” Cathode Tube UV / 5-12” Cathode Tube UV
    Dec 2006
    Athens, Greece
    0
    It just says UV additive blue on the bottle and I bought it from Alphacool online store.
    But really could it be the silver wire I use in the loop?
+ Reply to Thread
