10th anniversary problems
i can get this set to 586mhz 2.2v cl5 32m, ortos stable but i cannot go any higher regardless of voltage, i have tried up to 2.45v without any success. It will boot to the windows screen even at 2.2v 600mhz but freezes and reboots straight away. This happens regardless of voltage anyware above the above clocks. my system consists of
Biostar p965 deluxe
e6400
enermax noisetaker psu
i have also tried sever different bios revisions from both the stilt and rebels haven with no success. I know the board and cpu are capable of higher as my pc8000 ballistix got to 616mhz.
I suppose the most logical explanation is that this is just the limit of the ram but i find it odd that it would go from being stable to not fully booting within a couple of mhz even with an extra .25v. all my experiences with ram have differed from this.
Anyway thanks in advance for your help!!
Are you running 1:1 or 2:3, or 3:5?
thats running 2:3. i cannot run any other divider as my cpu isnt capable of much more than 3.4ghz
- You may not post replies
- You may not edit your posts
Forum Rules
