Processor - Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor
HSF - ZALMAN 9700 LED 110mm 2 Ball CPU Cooler copper
MotherBoard - ASUS P5B Deluxe/WiFi-AP LGA 775 Intel P965 Express ATX Intel Motherboard
Ram - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered Dual Channel Kit System Memory Model F2-6400PHU2-2GBHZ - Retail
Video Card - XFX PVT80GTHF9 GeForce 8800GTS 640MB GDDR3 PCI Express x16 Video Card
PwrSupply - Enermax 620W
Main Harddrive - 250gb
Slave Drive - [internal] 250gb IDE, [internal] 250gb SATA, [internal] 500gb SATA, [external] 320gb IDE w/ Vantec encloser
Optical Drives - 2x LITE-ON Black IDE DVD Burner Model SOHW-1693S Black
What cooling you got? :O Good temps. I'd be inclined to believe CoreTemp
uhm 9700Originally Posted by pois0n
hmm, wow. Really nice temps you got there bud.
Anyway, id have to say use CoreTemp...
So far its been the most accurate for Conroe temps.
Intel E2140 @ 3.2ghz Lapped
TT Big Typhoon Lapped
Asus P5K-C
2gb OCZ Gold ddr2 800mhz
8800GTS 320mb
thanks, i just didn't know which temp moniter to believe. since coretemp is the case, damn straight i have good temps.Originally Posted by SkylinGTR26
what is the max temp for warning on a core 2 duo?
nvm i got the dual superpi to work.
wow, nice temps you got there!! but I can hardly believe that 39°C is the true temp (unless you have your rig standing out in the cold...^^)
But then why is the TAT showing 51°C??? Very strange...
I think CoreTemp is the most accurate temp...I will try that TAT out as well once I got home...![]()
