Page 2 of 6 FirstFirst 12345 ... LastLast
Results 26 to 50 of 131
Thread: Project: UFO
  1. #26
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    great project
    i like watching such project where a case is made from the scratch
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
  2. #27
    all outta gum
    Dec 2006
    Poland
    Where did you buy that PSU bracket and mobo tray?
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
  3. #28
    Apr 2005
    New York, USA
    I just started planning my own version of what you are doing yesterday! It's great I get someone to look at so I can learn for myself.
    The access point I'm using block's images from whichever host you are using, so I will have more to add once I return home. I can't wait to see your progress.
    Best of luck,
    Yan
    i7
    Dell 30" 2560x1600
  4. #29
    May 2006
    Quote Originally Posted by xoqolatl View Post
    Performance-pcs.com
    Core2Duo E6600 @ 3.0 - Load @ 32c°| Gigabyte P35 DS3P | 2gb Crucial Ballistix Pc2-8500| eVGA 8800GTX| X-fi Fatal1ty | OCZ GameXStream 600w | Custom Watercooled | Custom-built Case
    Dtek Fuzion | DD Maze4 Acetal | Swiftech MCR-320 | DD D5
    3dMark01 3dMark05 3dMark06 Aq3 SuperPi
    Quote Originally Posted by Movieman View Post
    I don't beleive in passive cooling.
  5. #30
    I am Xtreme
    Sep 2006
    Great another Cubo modder, damn these things are taking over the world Looking good mate , keep it up , this is the fun stuff once you go into details it will move at a much slower pace...
    Love to see it when it's finished ...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  6. #31
    May 2006
    Leak testing now
    My temp setup:
  7. #32
    May 2006
    Added a nice blue hue from some pentosin.
  8. #33
    Apr 2005
    New York, USA
    Hey I was wondering what you did your drawings ( http://img.photobucket.com/albums/v603/MrMage/case5.jpg ) with? Over this summer I came up with a design concept, and I've been working on it further, but I want to make more detailed drawings, such as you have.
    Keep up the good work.
    Yann
    i7
    Dell 30" 2560x1600
  9. #34
    May 2006
    Solidworks '06
  10. #35
    May 2006
    Got more done today! I'm on a roll!
    Before I show the pics, I just want to say that this gel stuff from petras tech works amazingly well, my pump vibrates no more, and its a D5!
    Installed the fillport
    Another shot
    Here are the holes I cut by hand with my dremel
  11. #36
    I am Xtreme
    Sep 2006
    Good one mate , things start to fall nicely together, are you gonna powdercoat the alu or leave it like this ?
    Also is the NB gonna be cooled aswell via H2O, I only spot some copper heatsinks on it , is that sufficient to warranty a stable overclock ?
  12. #37
    May 2006
    I would like to paint the alu, but I am not sure when I will get to it. I saw your post of your cube, and it looks great as well, but I was curious, how much was it to powder coat it? And, where did you send it to?
    In the near future I do plan on putting a nb wb into my loop, along with a dual ddc+ pump setup, but for right now, I have a pure copper heatsink on it.
  13. #38
    Oct 2006
    England
    If you’re going to paint the case because it is alu you will need to prime it with etching primer or the paint will just flake or chip away.
    Good work on the case though, look forward to seeing it all finished.
  14. #39
    May 2006
    Yeah, I tried painting alu on a project a few years back w/o primer.. the paint didn't last a week =(
    Question: Is the temperature diode on this digital thermometer(http://smg.photobucket.com/albums/v6...t=P2141188.jpg) waterproof? If not, is there some way to seal it, and still have an accurate reading? I want to put it in one of my tubes to get the water temperature.
  15. #40
    May 2006
    Stayed up all night.. finished transferring all the components into my case, besides cable management and adding come cathodes, putting some flooring, and cleaning up the cd drive cut-out, the inside is done!
    And it booted up!
    Initial test show temps dropped 10c @ idle to idle at 18-19c, load temp dropped 15-23c to load at 37c!
    P.S. The temp readout on the front of the case is reading inside case temp.
    Will post more pics tonight, for now, I need sleep!
  16. #41
    I am Xtreme
    Sep 2006
    I got mine not powdercoated but airbrushed , painst resistant and it was lacked in a car shop... was around 75 euro's ( live in Belgium Europe)initially, but I went too hard on the abrasive side so he had to prime it a lot and so price went up .
    I found a powdercoater for my next build and that is around 50 euro's, let's say 60 dollars or so
    I still strongly advise you to relook at the northbridg cooling, those small coppersinks won't cut it for hours of online gaming or overclocking mate, you will have to figure something out with a a fan or so...maybe just the stock heatsink with a fan on it ?
  17. #42
    Oct 2006
    England
    Quote Originally Posted by Vice View Post
    Know I don’t think it is, and it would not be worth trying to make it waterproof in case it failed, what you need is an inline water temp monitor, then go about seeing if you can mod it so you can connect it up to your equipment.
  18. #43
    May 2006
    Placed my paypal withdraw request today, should have the money in my account for my wheels on monday, will have them by thursday if all goes well.
  19. #44
    May 2006
    At last, I can finally say good-bye to the worst block I have ever bought, the Swiftech Storm v2.
    The block leaked on me, almost ruining my entire computer... and as I throw it in the garbage I hope I can finally... let go.
  20. #45
    Dec 2006
    Houston, TX
    Omg What Happened To That Storm!?
  21. #46
    May 2006
    Heh, the thing decided to leak on me because it is poorly made, so I had to seal it up with this aqua seal stuff from home depot
  22. #47
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    the case look really nice....
    lol your storm looks like it has gone trough a real beating... how in the hell it could have been made that poorly.. its not like there are a tons of treads about storm being a total crap block.. strange
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
  23. #48
    May 2006
    Yes, I'm pretty sure it was an isolated incident and I got a defunct block, but trust me, the one I had was made like garbage.
  24. #49
    Apr 2007
    Miami Beach, FL
    gotta give you credit where it's do. The case looks great ! I wish i had some time to do a project like that
  25. #50
    -100c Club Member
    Dec 2004
    Europe
    Really nice
    regards
    My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LN² Pots, LD GFX-R1 Dice/LN² Pots,
    LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
    LD PC-V8 Watercooling Cases:
    LINK
    LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
    www.ldcooling.com
    Find US on Facebook
