I can finally pass along some impressions of this new vidcard to you guys. Actually I was quite suprised at the overclockability of the video card with the extra 128 megs of memory onboard.
Since it's DDR II it does get hotter, so the card is pretty much completely sinked, stock from the factory. I took the stock HSF off and they had a good helping of TIM on it (I cleaned and applied my own AS3), then put the stock hsf back on the VisionTek Xtasy 9800 Pro.
It actually overclocked pretty damned well, perhaps just a hair under my 128 MB ATI Radeon 9800 Pro as far as pushing it very hard. I need better cooling before I do much more with the card at this point.
Also, I scored 145 points higher today than I have on 3DMark03...made it to 6660. I had to run my mem timings on the XMS3500 pretty relaxed at 230 otherwise it wasn't very stable. I need to squeeze more than 230 FSB out of the mobo, so tomorrow brings on the TwinMos PC3700, hoping to ride that up to 235 to 240 FSB hopefully.
Link from the 6660 run: (only 1500 or so behind OP!).
http://service.futuremark.com/compare?2k3=803556
This is all on air cooling by the way.
The Xtasy 256MB card comes bundled with the 6292 drivers, which do NOT recognize the 256 MB memory, if you bench, you'll only see 128 MB show up. So I ran the benches with the Catalyst 3.4's, card is unmodified at this point.
Here's some pics of the cards I am quite happy with the card, and VisionTek did a good job on this one. TigerDirect also did great in getting the product to me as advertised, I was impressed.
I have a comparison I'll throw up later that shows this card pretty much next to the 128MB ATI card at about the same settings. The 256 does better at a little slower speeds actually and performs pretty well.
