+ Reply to Thread
Results 1 to 5 of 5
Thread: oc not stable!
    Nov 2006
    0
    oc not stable!
    I have a E6400 im trying to get 3.2 ghz out of it it is stable in othros 12hrs super pi and all but when i play BF2 after a while it freezes!
    i have my ram at stock 800mhz i bumped the vcore up to 1.45 in the bios still nothing!
    can you recomend any other settings?
    Xtreme Addict m0da's Avatar
    Jul 2005
    ATX
    0
    It might be your graphics solution.
    Make sure you have the latest drivers installed (check nVidia or ATI website)
    Also, if your graphics card isn't getting enough power, it might be affecting your gaming. What PSU do you have?
    Nov 2006
    0
    i dont have the latest drives! i have the 8800GTX and a OCZ 520 powerstream!
    Xtreme Member brickout's Avatar
    Dec 2005
    Bozeman, MT, USA
    0
    You need to provide more information. Make a list of all your hardware and the major settings that you are using.
    Log temperatures while you play and see if that is the problem. And get all the latest drivers as m0da suggested.
    c2d/4gb ddr3/5870/Antec P150
    Xtreme Member mele's Avatar
    May 2006
    Statesboro, GA USA
    0
    PSU may be the issue here?
    Not enough to drive the 8800?
    MEl
    MB: Asus Maximus V Extreame/SLI 1501 Bios Cpu:i7 2600k @ 4.6Ghz (24/7) (1.34), FSB 100x46
    Ram: GSkill PC3-17000 2x4Gb @ 2133MHz, 9-11-10-28, 1.65v
    Gfx: 2 ea EVGa 480GTX HydroCopper SLI/ Mon: 2 ea Dell 2407 FPW LCD 24" Widescreen
    SSD: Corsair G Force 3 240 GB
    PSU: Corsair HX1000W
    Cooling: Cpu: XSPC Raystorm / Swiftech MPC655 / 1X360 BI II RAD & 1X240 BI II RAD
    Temps: Cpu: 26c Ambient / 28c @ Idle / 68c @ 100% Load (Folding) | 2 480hc 75c @ 100%
+ Reply to Thread
