What's the deal?
Danger Den Black Ice GT Stealth 360 vs. Danger Den Black Ice Xtreme III Radiator
Which one is better? The specs on the GT stealth say it gives the same performance in a thinner package.....
What's the deal?
Q9450(341x8, C1)(50, 47, 47, 50 Load, AC MX-2)(Apogee GT,non-bow)
TRI-SLI 8800GTXs (575/1800)(EK 8800GTX Full Covers)
Asus Striker II Formula Mobo (BIOS 1101)
4 GB Corsair Dominator DDR2-800(4-4-4-12/2.1v)
4 x Segate 320GB Raid 0(~175MB/s Avg.)(~280Mb/s Burst)
Asus 16x Dvd-Rom 2MB Cache, Lite-On 16x Burner/Lightscribe
Enermax Galaxy DXX 1000w, MM U2-UFO DUALITY (JUST BOUGHT U2-UFO CYO!!!! Duality Front, Standard Back, Smoked Grey Acrylic Side Panels)
Windows Vista Ultimate
42" Westinghouse 1080p LVM-42W2 Monitor, Logitech Z-5500 Speakers, 2 x MCP655 Pump, 2 x EK-200 Reservoir, 2 x Thermochill 120.3 Rads
(Signature Pic is when I had the HORRIBLE Evga 680i board)
AMD PX4 9600BE($75), DFI LP DK 790FX($130), 2GB OCZ DDR2-800($40), Zotac 8800GTS 640 ($120), OCZ 600w($60), Rocketfish Case($100)
i have the bix III and it is really hard on fans, i.e. high fin density, therefore loud. i dont know how it stacks up to the stealth. i cant really comment with my temps as my rig is apart and being revised
The Stealth is designed with lower cfm fans in mind due to its fin spacing whereas he BIX is designed to work best with ultra high cfm fans...
Originally Posted by Chruschef in regards to Thermaltake water cooling
I have the Danger Den Black Ice Xtreme III Radiator and it's a monster, i just love it..
but i don't build silent systems.... lol/
HWbot - Team: XtremeSystems
XS cruncher - Team: XtremeSystems
OCN Feedback
HEAT
*** Being kind is sometimes better then being right.
Just a reminder the BIX!!! hold twice the water and HAS TWICE the Flow of the GTS stealth...
Ive ran both side by side....The GTS has more back presshure where the BIX !!! flows twice the amount...
The Bix !!! and GTS using panaflow 86cfm fans...
The Bix !!! gave me lower Load Temp and Lower Idle .
Both were run with a D-Tek W/B and 655 pump..
THE GTS likes Medium FLOW(50cfm) to High FLOW(86cfm+) fans for it to cool decent ..
Note:
A MCR does better than the GTS hands down with either Low or High CFM fans.. The BIX !!! using low CFM performs better than the MCR with Medium/High CFM,,Because of Flow rate and Water Volume..
GTS/MCR 12rows/Restictive flow Vs BIX!!!24rows High FLow.
Quality and cooling capacity i chose BIX !!! over MCR and GTS.
Fans to run on BIX !!! I recomend 86cfm for optimal function(low CFM works great too).. BIX !!! will handle multiple blocks(VidGPUcooler/NbCooler) easier..Water Flow Rate is close to double that of the MCR/GTS .
For the Price (below $55bucks easy),,High water Volume ,,Highest cooling with Low or High CFM fans the Bix !!! A nice durable heavy contender in the Midrange Rads.
If you cant fit the BIX!!! ,, go with a MCR Qseries(better flow and use of Low CFM fans over the GTS .
..If you want the Best for High Waterflow/Low CFM fans and have Money get a ThermoChill PA 120.3 and flush it twenty times before use
The THC Feser 360(shorty clone of PA) is nice but a hair overpriced for what you get...the TC/PAseries still has the low CFM edge....
For High Flow CFM Cooling Above 2000RPM 100+cfm fans then grab a GTX360,,You must use High Flow for this rad to perform..
Martins results are memories,, or id show you benches....
P.S.
Martin ,,,,enjoy ,,youve helped many..
The Black Ice GT Stealth is bull crap, and offers lower temperatures than an MCR320. It is also way to thin to be used for anything, but a space restricting build, in which case you would not be watercooling to begin with. The BIX III also works fantastic and can cool lower than even a PA 120.3, depending on what fans you use on it. Given it will sound like an airplane, I'm just explaining the potential of the higher fin density.
Current Computer| Modified SwordM | EVGA 680i A1 | 3x EVGA 8800GTX | Q6600 @ stock | 4 gigs Corsair Dominators 1066 | WD Caviar 1TB 7200rpm | Liquid by D-Tek and Ek
Friends don't let ANYONE use Thermaltake
Conspiracy Theorists FTW
Join Us http://www.xtremesystems.org/forums/...php?groupid=25
My 680i A1 is not responding... WTF
U guys totally took this off course i think
U have the right GTS, but the OP i believe is referring to the Black Ice Xtreme III NOT the GTX.
Its under Xtreme in the DD website. Thicker then the GTS but not the GT Xtreme
http://www.dangerden.com/store/produ...&cat=85&page=1
Still, just don't get the Stealth, anything is better than that.
Well yea instead of the Stealth id definitely get the MCR....
But u guys were all hyping about the GTX and im like hmmmm i dont think thats what the OP was asking for lol
$150 radiator versus $50 radiator....unless its the MCR i dont see how theres a comparison :P
All stock for now, no need for more, but it's gonna be soon methinks.
Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
SLI GTX470 EVGA
EK HF nickle blue top CPU block (free from Eddie)
Koolance 470 waterblocks
One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
Banchetto Tech Station
120 GB SSD, and a few other drives.
1000W UltraX3 PSU, 900 watt (1500VA UPS
23.999" Acer GD235hz and 24" Acer H243H
Must admit, i'm well and truly happy with both performance and noise levels using a Black IceŽ GT Stealth 360 XFlow cooling 2x QX9775's at 3.2GHz and a Danger Den MPC-Chipset (hot) all in the same loop.
Sure, things get a bit warmer at 4.2GHz with increased voltage to all three chips but that's why the fans are on Scythe Kaze Master controllers so nothing a little more RPM can't handle
The GTS360( 29mmRad) to the BIX!!! (40mmRAD)..
THE BIX !!! is better all the way around despite that HWlabs says it performs @ BIX !!! level in Stealth Mode..ive tested it and the BIX !!! won no matter the fan size .
BTU'S ,
British Thermal UNIT,
Thermal output or Dissapation in One Hour,,
The GTS360 is only capable of 8200BTU's,,***
The MCR series 320 capable of 9000btu,,
The BIX !!! is capable of 9700BTU's,,***
The GTX360 around 14800btu,,
The PA 120.3 series @ around 15435btu...
Volume SIZE(HxLxW) ,, Bigger channels and More channels(tubes)usually determins how Quik it can dissapate the heat to the fins to the AIR..Your Fan speed(CFM) determins how fast this happens.
NOTE:***
BIX !!! displaces more HEAT,, Thats really what matters between the Two.
BEST rad,,
i would buy is the PA120.3 coupled with HighCFM or low CFM fans if i need quietness .
Second ,,
a GTX360 with High CFM fans ,,they can be had for $85bucks(budget price)
Last,,
OLD New 360 Xchanger FESER (17mmfan spacing.)The revised NEW 15mm Fan spacing is $120 on average,,Go figure..
More about GTS360 vs BIX!!!
The GTS falls behind because of its restrictive flow and the fins are too dense/low air flow still for single row rad(30fins per inch)
(BIX!!! is 18fins per Inch) twice as thick but still performs better than GTS for good low CFM fans..
Also remembering Martins info ,,
GTX 480 with 1880rpm fans performs ahead of THC FESER X480 and ThermoChilly PA 120.3 @ 1.5gpm/2.0gpm ,,
Based on the Charts that were out there ,,Im positive High CFM went to GTX 360/480..For Low CFM its PA120.3/ then comes THC FESER 360 which is close to the PA 120.3 but its not the same...
The PA holds more water volume than Feser with slighly longer Cooling channels and thus has that extra edge on the FESER no matter if it was using Low/High CFM fans.
The last two Rads ,,Have been the Most exspensive of 3x120's particularly FESER.
Hmm hope i typed that right
u typed it right BUT WERE NOT COMPARING the BIX....read the other posts...
The GT Xtreme is not the Xtreme III (post #8)
The Xtreme III is a cheap rad like the GTS but is thicker...i mean there is no valid reason to go with GTS vs. BIX they are totally different in price, but the Xtreme III is much cheaper
Guys i just ordered Danger Den Black Ice GT Stealth 360 and my loop is going to be only for CPU , so i just need to know i order 1L of coolant is it going to be enough for Swiftech H20-220-APEX and this radiator?
