I'm currently starting with a project and i'll need some xtreme input.
I'm going to write a program that will make it much more pleasent for us to do some extensive benchmarking. Anyone who has written a review of motherboard/cpu/vidcard comparison knows that 80% of your time is consumed by running a benchmark program, writting down the results, importing them to an excell sheet and turning it into a good looking graph. This is a very timeconsuming and repetetive task, which can be automised.
My goal is to write a little app, that will allow you to select a few popular benchmarking tools (eg. UT2003 bench, Superpi, 3Dmark, ...), starts the first automaticly, extracts the results when done, closes it and starts with the next one. When all selected benches are finished, all the data is put into a snapshot-ready graph & into a text file (with delimiters, ready to be imported by excell). Saved results can be compared to other results, to make comparisons between different mobo's/vidcards/... easy.
In a nutshell:
- select the benchmarks you want to run
- select options (eg. 3D in low res to test CPU/Mobo)
- start. The app will run the selected benchmarks in sequence and extract the results.
- join the results in a premade graph (for quick screenshot) or output to a excell compatible .txt file for import.
That's it. It would be opensource java.
What i need from you guys?
* would you use (it if it ran perfectly)?
* which benchmark progs should be included? Remember the results have to be extracted somehow, this will not be easy in some cases. Also, there should be a way to start it immediatly (and not wait for user input).
* what kind of output other than specified do you want?
* other comments.
