I have this as current rig, sit back for a long story, becaus im totally confused to this point..
Ok Current rig
duo 6300 L627A637
P5B DLX latest bios shipped
OCZ 600W SLI ADJ
2X1024 Team 667 D9GMH
Raptor 74
7950 GX2
Well I used to run this stuff on a DS3, and it was pretty decent little clocker exxept for the fact that it never could run past 462 FSb X 7 = 3.2ish, I and others figured this was the boards max, so I recently bought a P5B DLX, Tuniq Tower 120, and 2 60mm's to cool the rams..
Installed all this and im basically @ the same road (Ive managed to hit 468X7 but southbridge needs 1.8), what could be my problem now, Ive read through all the P5B posts and tried a ton of different setups as far as timings and turning on and off this setting and that, I can boot in @ 417 3-3-3 which would be awesome if I had a better multi, but X7 thats garbage..
Im wondering whats the problems here..
Shell do 460 @ 1.365v cpu / rams @ 2.1v 460 4-4-3-8
Ive raised ram to 2.4 cpu to 1.55 south bridge will get me in @ about 468 but needs 1.8 south and Im not confortable with all that, I thought this was a good setup for 500+ fsb, as of yet I havent been able to acheive that at all...
Any help will be greatfully appreciated and tried @ the second I receive it and will post back..![]()
Cmon fellas help me out, I have a feeling it isnt the ram or mobo, but either the mobo or PSU? I thought my OCZ was a beast, I really have no dam idea though, so anything will be tested and retested to insure accurate feedback..
![Send a message via ICQ to [cTx]Philosophy](images/misc/im_icq.gif)
![Send a message via AIM to [cTx]Philosophy](images/misc/im_aim.gif)
![Send a message via MSN to [cTx]Philosophy](images/misc/im_msn.gif)
) and it's running 466FSB 24/7 @ 1.38v . Did 1M SuperPI with 505FSB once , my RAM is limiting it to go higher. And the best thing about it is it's running ~5C-7C cooler than P5B-D. So sometime it's not the chip , might be something else. Could be your mobo, settings, or other things. Grab the e6400 L632Axxx for the P5B-D and it's still struggling @ around 450FSB.
