Look very nice and i expect some great results from this.
hmm wouldn't work too well without some modding on a naked CPU
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
And how can you say that ?.
And to peep who posted about the back heatsink at bracket area, if you read threads here you can see some get temp drops sticking heatsink on there like on the TT-BT etc etc.
http://www.overclock.net/faqs/70395-...ps-my-big.html
They would get better temps if they used Artic Silver epoxy not tape.
It uses the clip on the plastic bracket around the CPU socket. Popping the IHS off makes the contact surface that much lower so those clip-on heatsinks won't mount at all or with not enough pressure. Something would have to be modded to make it sit right on a naked core (mod the clip to make it bolt-through, cut the plastic bracket down, something).Originally Posted by humeyboy
That thing looks nice. ican't wait for reviews of this and the coolermaster geminii.
that's funny.Originally Posted by enz660
(it's a sad day when you can't give a head's up about a new cooler)
2700K @ 5.0ghz / SLI GTX 670's / 16GB Mushkin / H100
the chipset cooler looks interesting.
Those guys at ocforums surprise everytime with nonsense stuff :S.
On topic: nice "HS" . Any good review to read?
"Study hard my young friend"[/B].
Woody: It's not a laser! It's a... [sighs in frustration]
i thought of the silverstone sinks as well ...Originally Posted by Mike EFix
all in all, i'm just not sure about the downward pointing heat sinks ...
something about working with case exhausting is just more attractive to me ...
http://www.heatsinkfactory.com/Enzot...r-p-16492.htmlOriginally Posted by Praxis1452
try it and tell us how it is
Work and School, Work and School, oi!
I like the pin dissipation over the base. 120mm fan 62-82cfm is good, as well as a smooth contact surface. But only 4 heatpipes? C'mon! This looks like an improved version of the aerocool xfire (or the nitrogon above) which is a good but not great hsf...but testing will tell.
i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
Asus P8P67 Vanilla
Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
Diamond HD 7970
WD 600GB Velociraptor
Corsair TX750W
CM 690 II Advanced
Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
downward pointing sinks blow air across the mobo as well which helps to cool the vregs, mosfets, and (depending on board layout) the northbridge if it is passive. I had to replace my stock passive northbridge cooler because I have a tower cooler and the lack of airflow was making it get awefully hot. My vregs/mosfets/coils still get kind of hot though, I haven't figured out how to cool them off yet.Originally Posted by s1rrah
Looks like an enlarged Thermalright SI-120.
Originally Posted by quicksilverXP
This Enzotech weighs more than the Tuniq coming in at 835g, Tuniq is 798g give or take depending on the fan you use.
difference of 37g. Making the tuniq more effective and weighs less? But I would love to see a comparison of Tuniq to this if anyone happens to come upon one.
Man... you're right. Didn't catch that... I was looking at the weight without the fan.
tuniq has only three heatpipes....take a look at how its doing, lol.Originally Posted by LagunaX
Specs:
- e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
- P5W DH Deluxe Cooling Mod
- 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
- Nvidia 8800gt
- Silverstone ST75F 750watt
- Modded Asus Vento (Black) *Heavy Case Modding In Progress*
3 other factors about the heatpipes needs to be considered here:Originally Posted by enz660
Ultra-X heatpipes are 8mm in diameter, that is a plus.
Ultra-X heatpipes seem to have better contact with the heatsink, that is a plus.
Tuniq heatpipes pass through the heatsink in the middle, which is a plus for the liquid and vapor flows, while Ultra-X heatpipes terminate at the heatsink.
I think the Ultra-X does have a chance to beat Tuniq.
Intel CPU: C2D Xeon 3060 L628B211 3.60GHz (oc 24/7) @1.40v in Bios
CPU Cooler: Tuniq Tower 120
M/B: Intel BOXD975XBX2KR Rev 503
DDR2: Crucial Ballistix BL2KIT12864AA1005 + Crucial Tracer BL2KIT12864AL1005 @ 400MHz (1:1) 3-3-3-8 @2.32v
Video: Gigabyte GV-NX76G256D-RH
LCD: Samsung 225BW
Raid1: Samsung 7200rpm 8MB HD400LJ 400GB
PSU: Sunbeam SUNNU550-US-SV
Case: Lian Li 1200B Plus II
I'll buy one if it beats the tuniq, but the tuniq does have 6 legs going up vs. 4 despite the base connections = more conductive surface area and volume, but the enzotech's pipes are thicker...we'll see.Originally Posted by enz660
Asus P8P67 Vanilla
Diamond HD 7970
Corsair TX750W
CM 690 II Advanced
The contact of the Ultra-X's heatpipes are much better than the Tuniq's contact and the Ultra-X got that little heatsink. I think the Ultra-X has a chance to beat the Tuniq.
yes, i think it might... i like my tuniq a lot but i do prefer horizontal sinks, to be honest - saves me lots of trouble cooling the n/b, mosfets and what have you.
enz660, sry ocf closed the thread, man. don't just take it though, pm them and tell them they did wrong.
dothan 730 @ 2.6Ghz l p4c800ed l 4x512MB bh5 2-2-2-5 5:4 ~3v l Antec Neo 480
e6600 @ 3.6GHz l P5W64 WS Pro l 4x1GB D9GMH (B6-3) 3-3-3-3-12 4:3 2.2v l PCP&C 750
Think ill buy an Ultra-X and find out how it holds up with my Tuniq using a few different fans and thermal pastes. Will order when I get outta work.
EDIT:
Will post results when I get it using 3 different fans, and 2 different TIM's.
Tuniq - Ultra X....Should be interesting.
whoaOriginally Posted by ChaosMinionX
This is going to be the most practical review for overclockers.
Another important factor is the heat load. Although I know you're running a C2D at 3.60Hz or higher, I wish you had an overclocked C2D quad to load them to the extreme.
Ultra-X has a chance to bite Tuniq 120. However, only real tests will tell.
Eager to know when your're going to receive it.
LCD: Samsung 225BW
HeatsinkFactory.com has it as Pre-Order. ETA Feb 12th.
So, ChaosMinionX, you have to wait for your new toy for at least 1 week or more.
LCD: Samsung 225BW
all I'm thinking is that this is a nice GPU cooler.
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
