+ Reply to Thread
Results 1 to 4 of 4
Thread: my 1900+...
    Jun 2002
    Marietta, GA
    0
    my 1900+...
    Alright, my rig is in the sig, I am only able to get 146 fsb out of this chip stable. Stepping is AGKGA "9" I believe..
    I have pulled every PCI card out, leaving only my ti4600, CPU, RAM, HDD and CD-Rom.... Could it be my RAM? I don't think so, since it's rated at least PC2700 or 166fsb, any input? I'm getting pelts soon/making a bong today or tomorrow.... I'd like to know if I need a new chip to get jack squat out of it.
    AMD Athlon XP 1600+ @ 1848mhz | ABIT KD7-R | 2x 256mb Corsair PC3000 | Gainward GeForce4 Ti4600 | 60gb Maxtor 7200RPM ATA133 | Enermax 431watt PSU| Cooled by SLK800 w/ Vantec TornadoH20
    Registered User Paul.K's Avatar
    Jun 2002
    0
    The first question is the chip unlocked??? This could be one of your problems!!! To make sure it is the RAM drop your multiplier down to say 8X and set your FSB to 166 like your memory speed. Make sure you enable the 1/5 divider in the softFSB menu. Relax the timings on your RAM in DRAM settings e.g. Cas2.5 4, 3,6,3 2T etc. and test and see if the machine will be boot and run stable.
    Paul...
    Watercooled O YA BABY......
    Registered User Maximus Nickus's Avatar
    Jun 2002
    Milton Keynes, UK
    0
    All chips differ tremendously, you can't expect a great overclock with every chip, most chips will overclock a fair bit but never get your hopes up.
    That way you won't have the disapointment of not reaching a high overclock.
    Firstly I would unlock the chip, and lower your RAM latency's to enable the RAM to go a little further, also remove all PCI cards. See what you get then put it back together bit by bit, you can then diagnose the source.
    M_N (www.overclockers.com)
    I'll be back
    Folding at Home, join us!
    Proud Member of the 3DMark Oc'ers team
    My Heatware
    Be calm, Relax, and the answer will come to you
    Jun 2002
    0
    First off it is well known that overclocking with the AGKGA Stepping is pretty much a turkeyshoot! if you want to get better overclocking results I would personally look into a chip with the AGOIA or AROIA Steppings they overclock tremendously, also I'd get the 1600+, because it is the answer to the intel 1.6a (funny how both of the 2 manufacturers major overclocking chips are both based around the 1600 mark!) Most Athlon XP1600+ Cpus can overclock to at least 1750mhz at 1.8vcore, if you get an arioa and some wicked air cooling you could even get it to 1900mhz which is a 500mhz increase! (not too shabby on the amd front).
    Unlocked AMD Athlon XP1600+ @ 1710mhz (9.5x180fsb@1.8vcore)
    Thermalright Sk-6w/50cfm delta fan
    Idle 40c full load 45c
    Asus A7V333
    256mb Corsair PC3000 Cas2 DDR
    SoundBlaster Audigy
    3Com Etherlink XL
    Leadtek Gf3 Ti200 Clocked to 220/500
+ Reply to Thread
