Originally Posted by $+€\/Ø
I don't know if it's suicide I've put together a one-loop system the only items that I'm NOT cooling that you are is the ram & mosfet's (and I probably would have if I thought of it sooner, realized how hot they got).
From your case diagram and pictures it looks like it would work w/ two pumps. Mine is using just one MCP655 (trying to cut down on the components even w/ the G70 lian-li case it's tight with everything installed).
With one pump I would probably do something like:
Pump -> rad -> vreg -> cpu -> NB -> GPU1 -> GPU2 -> SB -> RAM -> Res -> pump
Though w/ 1/2" tubing with all of that in the system you'll probably find it tight especially around the SB area (at least it was on the striker extreme that I have). You will want to get some anti-kinking either coils or something around the tubing (I use tygon and some of the bends are still rather tight). However w/ the PA120.3 that I've got it keeps everything cool (granted I'm not trying for an OC record here either).
