Dudes,
Yup, first post, been lurking here for a while, need some advice on the routing of my coolant loop(s).
Here's the rig, already bought the parts so I don't need any advice on the components (although you may beg to differ):
mobo: Asus Striker
CPU: QX6700 w/ D-tek Fuzion
GPU: 2x eVGA 8800GTX w/ EK-FC8800
RAM: OCZ FlexLC (4gb)
NB: DD680i
SB: SwiftechMCW30
Res: Alphacool Cape Coolplex 25
Rad: BlackIce 480GTX
Pump: SwiftyMCP655
tubing: 1/2" & 3/8" Tygon
I'll be OC'ing some, but I'm not looking to break any records.
At the moment I'm thinking of a loop like this:
Res->Pump->rad->'Y' 1/2"-3/8"->RAM->'Y'3/8"-1/2"->CPU->GPU1->GP2->NB->SB->res
The logic behind this scenario is this; shortest and cleanest lengths of tubing; RAM won't dump much heat; CPU should be cool; NB & SB won't need as much cooling
Looking for alternative ideas, but as I said, I'm commited to an all water setup and these parts. Don't bother flaming me - I won't take the bait.
Thanks in advance.
~$+€\/Ø~
