+ Reply to Thread
Results 1 to 5 of 5
Thread: Power Supplies...Too little or just enough?
    May 2003
    Oregon, US
    0
    Is a 300w PSU adequete for what im running?
    AMD Athlon 1.4Ghz
    512mb DIMM
    40GB HD
    GeForce2 Hercules
    DVD-ROM
    36x CD-RW
    Side Case Fan (80mm)
    Front Blue LED Bars
    Soon to Add:
    Rear Exhaust (80mm)
    Top Blowhole (120mm)
    Also I tapped into a molex connector to draw power for my blowhole and my PSU died. I tested the fan in the PSU and it works, and tested the fuse also and it works. I am using the same PSU but a working one. So 1) Should I get a bigger PWU and 2) How could I fix my old one?
    Oct 2002
    0
    Welcome to Xtreme!
    Can you explain what happened when you tapped into the molex? Was the computer on?
    I think 300W is more then enough for that computer. I don't know about fixing it. I'm sure that you could find a cheap 300W PSU for sale. I think there are some Cheap ones for sale in our for sale forums right now.
    P.S. You might want to remove those ads from your sig before a mod sees them. You can't advertise here.
    May 2003
    Oregon, US
    0
    Ahh thanks wdd! Well a molex connector has four wires:
    Yellow-Black-Black-Red
    I found out using a volt meter that the Yellow wire was the hot wire. So I took out the yellow and black wires from the molex (Using a sharp dental tool to undo the clasp). Then I soldered two wires: One on the Yellow and the other on the black. I did this becuase I am putting all of my fans on switchs that are located on a 3 1/2" Bay cover. So I plugged my machine in and tried one fan with the switch: It worked great. Did some more soldering and molex modding, and tried the second fan with the switch: It worked great. So I closed up my machine and left for a couple hours. When I came home I hooked it all back up and turned it on: For about 1/2 a second it turned on (Hence my Blue LEDs on the front lit up) and then it shut off. Tried the switch again: Nothing. Tried my PS again and nothing. So I unplugged it, plugged it in and then it did the same 1/2 second start. I clipped the wires and unplugged ALL of my fans and my lights and it still did the same thing. Luckily I had an identical un-modded PSU and so thats what im running. So no my computer WAS NOT ON. Im not that much of a newb :p
    CCW
    Guest
    Welcome to the Sickness!
    Id say a 300watt PSU was not adequate for that system, The chip alone draws a hefty chunk of go-juice and Id recommend at least 350watts but better 400watts.
    Craig
    Xtreme Mentor
    Nov 2002
    Canby, OR
    0
    hey, another oregonian!
    welcome to XS, NotSoSimple!
    you might want to pick up a better PSU, i never used less than a 350w on my 1.4GHz Tbird.
+ Reply to Thread
