alright i got my powersupply back. so, i'm going to go into my BIOS and set these settings:
HT multiplier : 3
Memory: ok, should i set the timings to 3-4-4-8? or just put the memory on a 133 divider?
Vcore: 1.35 + 110%
HT multiplier : 3
Vcore: 1.35 + 110%
My Rig
DFI LanParty UT nF4 Ultra-D 4/06 BIOS
AMD Opteron 165 CCBBE 0615EPMW @ 2700Mhz
OCZ 2GB Platinum @ 225Mhz 3-4-4-8
eVGA GeForce 8800GTX @ Stock
WD Raptor 74GB WD Caviar 250GB
You can try both ways. You would be better off using the lower 133 divider for now, just to be sure your CPU is stable before before trying to OC your memory.
Have fun!
yeah i applied all of those settings, and went to hit apply on clockgen with a 220 FSB, and i got blue screen.
My Rig
704BTA ftw (best overall bios imo)
What is the stepping on the 165 ?
OCZ guys is he running UCCC ? If so, throw it on 3-4-4-8 and hit 250-260 w/ the 6:5 and your set.
Dont overclock in windows, used the intergrated MEMTEST to find out how high your memory will go.. thats memory
Then lower your cpu mult and put your memory on a huge divider and find your max FSB/HTT.. thats your max FSB/HTT
try and find a sweet spot between the two.
This is a MUST READ
http://www.diy-street.com/forum/showthread.php?t=20823
Asrock Z68 Extreme4 Gen3
•i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
•G.Skill F3-12800CL9D-8GB
•ASUS 7850 @ 1250//5800
•Corsair TX650 V2
•Dell 3007WFP
•Win 7 64 Ult
what vcore should i use? my temps have been pretty hot lately. the cores are running at like 37°C idle...
My Rig
You want to make small bumps in the Vcore, but only if you need it. You will need very good cooling to allow overclocking and higher voltages, as both will raise your temps. Get your cooling straight first.
Read the link in the last post. Having all of it in front of you in a guide is MUCH better than getting bits of info here.
do i have good stepping? (see sig)
My Rig
From what I understand the stepping you have is ok to good but there will be many people that know better than me.
I am also new to DFI and A64 overclocking, but have been reading up on everything I can get my hands on (I like to read up on things first to get all the points of view) and from what I have see and understand you are much better off to do everything from the BIOS.
It will take longer but you will get a better understanding of what is going on and what you need to do.
I have sort of settled on the find the limits way of doing things where you turn down other stuff (via dividers) and see just how far something will go.
I am doing this with my CPU right now, I have my memory on a 1 to 4 div, I am doing this with some OCZ DDR PC-3200 Platinum EL stuff that I got, because I know that my G.Skill can do 260~270 so I thought if I learn on the harder stuff it should be easier on the other and also if I screw it up... With the memory like this I can see just how far the CPU can go without anything else holding it back. Then do the same with the memory and work from there slowly pushing things up.
I have been running just a few short tests to see how stable things are with the lower settings but more and more time as I get higher up, I let memtest 86+ run last night with everything just short of 2.6 GHz and had no errors after 8+ hours.
I have read that the LDT on DFI boards can just be left on auto and will reset itself to what is needed but I have put it onto 3x just in case
There are loads of guides I will let you find them its not that hard, but what I have found difficult is something that really tells me what all of the DFI BIOS settings are for, things like 'DQS Skew value and control' all the memory settings past the first 4, as all I have found just repeats what the BIOS says which does not really help.
I am also leaving the power settings alone for the time being I did not want to play with upping the volts just yet, so I will have something left for later
ASUS A7N8X nForce 2, AMD Tbred @2.012 GHz, 2GB G.Skill EL Plats, Radeon 9550 Seasonic S12, Maxtor 200GB x4 WD 74 GB, Win2000/Slackware
LG GSA-4167B - LiteOn SHM-165P6S - Optiarc DVDRW AD-5170A - Sony CPD-E500 & Mitsubishi Diamond Plus 200
DFI LP RDX200 CF-DR Athlon 4200x2 (LDBFE) Zalman CNPS9500 AM2 2 GB G.SKILL HZ PC4000, x1650XT 24Pipe, Raptor 150GB, 1TB Hitachi DS x4, 320GB Hitachi DS x2 Corsair HX 620 in Eclipse 62 - LG GSA H42N Optiarc 7200a - NEC ND-3550A - Asus CRW-5232A
also E4500 C2D & nF4 SLI-DR 185 opty via KVM
