Here's what happened when I plastic baggied a glob of AS5 evenly on the CPU and then gently put a a thin layer of Zalman's STG on both HSF and CPU.
That makes me thinking. If it was that easy, wouldn't diamond paste be out long ago?
Also diamond and one of the 3 hardest substances. Think about those pressure mounts people often use on cpu IHS and heatsinks, chipsets, etc on anything that needs a tim to transfer heat. Now pressure mounting with a paste that has diamond dust in it and a copper heatsink and copper IHS, copper is 'softer' than diamond. Overtime, wouldn't the diamond be pushed into the copper making microscopic groves?
Work and School, Work and School, oi!
I've ordered one Coollaboratory MetalPad for my Thermalright Ultra-120 eXtreme
But please enlighten me, can I use Liquid Pro on this heatsink? I've heard stuff which implies that it'll eat heatsinks not made out of copper.
Cool labs do not recommend you use an aluminum based heat sink
with Liquid pro as there is a reaction to the aluminum and the liquid pro
Hope this helps
Doc
Is the Thermalright Ultra-120 eXtreme made out of aluminium? I guess so, but you see, I'm clueless. Guess I'll go with the pads if that's it.
no ultra's base is made of copper with a nickel plating
MX-1 seems to be the best combination of thermal conductivity, safety, and price.
I use MX-1 too ... cheap, cheerful & effective
Just as a lil FYI.
Could be promising, looks like you get a decent amount for 5 bucks, before shipping. I'd say, maybe 5 to 10 applications. Not too bad.Originally Posted by overclockers.com
Originally Posted by heatsinkfactory
Sounds like it might be better than AS5 for NB,GPU applications , I very much doubt it will beat liquid metal though.
EDIT: Speaking of course about the 7carat diamond paste
No, this would not happen.Overtime, wouldn't the diamond be pushed into the copper making microscopic groves?
MX-II replaced my AS-5 about three months ago!
