with the pc1066 out, there is lots of confusion (in my head, that is).
if any of you know answers to any of the following questions, please post.
also, any other questions about RD-RAM, post them too
here is the difference between DDR and RD RAM:
DDR (pc2700, as an example):
(166 MHz Operating Speed) x
(2x Rising & Falling) x
(64-bit Bus)
/ (8 bits per byte) = 2656 MB/s available bandwidth.
RDRAM (pc800):
(400MHz Operating Speed) x
(16-bit Bus) x
(2 Rising & Falling Edge)
/ (8 bits per byte) = 1600MB/s available bandwidth.
RD RAM (the new pc1066)
(533 MHz Operating Speed) x
(32--(note, its twice bigger than the previous RD RAM) -bit Bus) x
/ (8 bits per byte) = whopping 4200 MB/s available bandwidth.
that, my friends, is 1000 mb/s more than the upcoming ddr400
so here are the questions:
1) when you upp the FSB, does your RDRAM's frequency go up too? with what rate?
2) how do they like extra voltage?
3) the bandwidth of pc1066 is 4.2 gb/s, and the i850e (intel 850e is the only chipset that supports pc1066) memory controller bandwidth is only limited to to 3.2 gb/s; why?
4) %-wise, how well does RD RAM overclock?
5) is pc1066 backward-compatible with pc800?
6) for a low end Northwood (1.6a) setup, if you plan to overclock to the max, is pc1066 worth it?
7) if you use a 400mhz fsb northwood, can you still make your ram operate at 533mhz (pc1066) ? (asyncroniously, that is...)
8) will pc1066 still run at 32 bit (instead of pc800's 16 bit) if you are running it at pc800 speeds?
9) whats the deal with the single/dual channel? do i need a special motherboard so support dual channel? does pc1066 have 32 bit bus and pc800--16 bit bus because one is dual and the second one is single channel?
thanks,
