+ Reply to Thread
Results 1 to 18 of 18
Thread: Geforce 8800gts
    May 2006
    Nottinghamshire
    4
    Geforce 8800gts
    My mate has a watercooled system and i wondered if there were any waterblocks that fit the geforce 8800gts!
    Dec 2002
    Sweden(Jönköping)
    0
    Yes both DangerDen and Ek has waterblocks for the GTS cards.
    Quote Originally Posted by Ugly n Grey
    I was watching late night TV and this was rolling through my mind all night.....
    "Why in the name of Papa Smurf would you put your d1ck in a hot apple pie?????????"
    May 2006
    Nottinghamshire
    4
    Does the mcw60 fit the 8800gts!
    Xtreme Cruncher [XC]Atomicpineapple's Avatar
    May 2005
    Lincolnshire, UK
    0
    Search button is your friend. However the answer is yes, but you'll need a ton of RAMsinks to cover the RAM, RAMDAC and power regulation components on the card, and yes the must be cooled or the card will fry, perhaps not immediately but soon after.
    Asus P9X79 Pro | i7 3820 @ 4.875GHz | 4x4GB Corsair DDR3-1600| 3x 6970 Lightnings watercooled| Corsair 1200W PSU | Mountain Mods Ascension case |
    May 2006
    Nottinghamshire
    4
    ill get that for my m8! Have already got my 8800gtx watercooled but with a factory fitted one that came with the card bfg!
    Xtreme Enthusiast cyberspyder's Avatar
    Jun 2006
    Markham, Ontario, Canadeh
    0
    Eddy's block spanks the DD block, that's all I can say
    Brendan
    I BLEED TOXIC GREEN
    Xtreme Addict Patriote's Avatar
    Aug 2006
    Montreal, Canada
    0
    Quote Originally Posted by cyberspyder
    Brendan
    Hehe, sorry to Hijack the Thread but i must say that i agree 100% whit your Sig cyberspyder!
    • - Asus P8Z68-V PRO
    • - Intel I5 2500k @ 4.5Ghz (for now)
    • - Asus Geforce 580GTX DirectCUII Fermi
    • - 16GB Corsair Vengeance Low Profile
    • - Ultra X3 1000 Watt
    • - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
    • - Corsair Vengeance 1300 Gaming Headset
    • - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
    • - CoolerMaster 690II Advanced
    • - Dell UltraSharp 24''
    • - Noctua NH-D14
    January - SLI Rig Of The Month (2008)
    Xtreme Enthusiast Mankz_91's Avatar
    Mar 2006
    Berks. UK
    0
    Eddy basically spanks most people....
    And his blocks cost less than DD's and look nicer..
    Jul 2006
    0
    exactly, however full-cover blocks can only be used on the block they were designed for, so I hope you like the GTS
    465 Watts of Computing Power....Running Off the Sun.
    **w00t for solar panels**
    Xtreme Member zerotol's Avatar
    Apr 2006
    0
    guys are there any full blocks that are single slot for the 8800 gts ?
    Now i am become death , the destroyer of worlds.
    I am Xtreme Zeus's Avatar
    Feb 2003
    Netherlands
    7
    Go with this:
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Addict Chri$ch's Avatar
    Nov 2005
    Germany
    0
    the EK Waterblock is really good...
    Xtreme Guru Solarfall's Avatar
    Jun 2006
    Finland, joensuu
    0
    i have to agree with Zeus and Chri$ch that EK waterblock is awesome.
    if you deside to buy it you will not be desapointed i can garenteen it.
    i've been more than happy with mine. best fullcover block out there imo.
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Jun 2006
    0
    Quote Originally Posted by Patriote
    very true
    Anyways, I'll be getting a GTS in the future, and I also want a block. Eddy sells two models, the Acrylic top, and the Acetal top. I prefer the black Acetal top, since it matches with my 'blakc' system. Is there any reason for me to get the acrylic version (I know acrylic cracks easily)?
    Brendan
    I BLEED TOXIC GREEN
    May 2006
    0
    If you like to see the liquid going through the block, take the acrylic version. It doesn't crack easily, it's just more fragile than delrin.
    Intel Core2Quad Q6600 G0 @ 3015MHz
    Gigabyte EP45-UD3
    MSI nVidia GeForce 7900GTO
    OCZ Technology Titanium PC2-6400 2x 2GB
    Corsair HX620W
    Samsung Spinpoint F1 320GB
    2x Maxtor DiamondMax 10 160GB
    Xtreme Guru JoeBar's Avatar
    Aug 2003
    Athens, Greece
    0
    Even though EK's wb's are top notch, i would decide on them if i was planning on keeping my 8800GTS for a very long time. Otherwise a MCW60 is a better option. My
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Banned
    Oct 2005
    0
    I speak from experience with the MCW60 and a GTS, you are looking at least 14 MCw14s, maybe 19 if you do it right, meaning upwards of 38MCW14s on SLI :-P.
    I know, I am doing it as we speak.
    Pics to soon follow, maybe this weekend.
  18. #18
    Aug 2003
    Athens, Greece
    0
    U don't need that many MC14's. I'm using only 11 (no cooling on voltage regulators), my 8800GTS is oc'ed @ 670/1030mhz 24/7 (atitool error free) and haven't experienced a single prob for the last month. I may add some cheap Coolermaster ramsinks on regulators just for the shake...
    BTW MCW60 and MC14 are reusable if u're going to compare costs...
    Project ZEUS II
    Watercooling setup:
+ Reply to Thread
