+ Reply to Thread
Results 1 to 15 of 15
Thread: Is 3M Scotchkote safe on PCB?
    Banned FragTek's Avatar
    May 2005
    Virginia, USA
    0
    Question Is 3M Scotchkote safe on PCB?
    Just curious as I'm thinking about coating around my socket and back of motherboard with it to help with condensation. Will it hurt anything?
    Thx in advance. Ez question
    Banned
    Sep 2005
    East Coast USA
    0
    No, that doesn't look like what you need.
    You need a conformal coating.
    such as:
    http://www.mgchemicals.com/products/419b.html
    that is designed for pcb use.
    May 2005
    Virginia, USA
    0
    Scotchkote isn't designed to be a permanent thing IIRC. Isn't it the equivalent of liquid electrical tape?
    Conformal coating is permanent.
    Xtreme 3D Team Member jimmyz's Avatar
    Jun 2006
    small town in Indiana
    0
    scotch cote is nasty stuff try plasti-dip it is what i use along with clear fingernail polish. scotch cote is almost impossible to remove from all the smds.
    May 2005
    Virginia, USA
    0
    Quote Originally Posted by jimmyz
    Rgr thx for that mate. I just decided to go with the nail polish and skip the Scotchkote. Been up for a bit now and monitoring condensation and haven't seen any yet!
    May 2005
    Virginia, USA
    0
    Quote Originally Posted by FragTek
    No condensation for a few hours, then it hit, and ate my new mobo with it... DAMNIT!
    I have a brick of non hardening duct seal that I was thinking about using around the outside edges of the socket (the area between the actual plastic socket and the metal hold down mechanism. I was just gonna cram it in to get out all of the air inside the socket area, would that work?
    Hell, could I use the duct seal on problem areas of the mobo, I don't think it conducts. Kinda reminds me of seal string, nasty stickyish but it comes in a brick.
    I'm thinking about Scotchkoting this next board I get too, in place of fingernail polish since I already have a bottle of the Scotchkote.
    I'm going to make it my friggin mission to ensure that I get no condensation whatsoever on this new board... I've now had my Vapo eat a brand new P5B and a brand new ICFX3200 within a week, not happy!
    Banned
    Sep 2005
    East Coast USA
    0
    use conformal coating. scotchcoat is prettty much permanent too. Sorry for your loss.
    Xtreme Member punisher69's Avatar
    Jul 2005
    Canada
    0
    What's wrong with using Liquid Electrical Tape?
    Q6600 @ 3600 Mhz
    ASUS Maximus Formula NON-SE rev 1.03G (Bios Maximus Rampage 403)
    4 X 2GB Corsair Dominators
    EVGA 8800 GT
    320G WESTERN DIGITAL / 74G RAPTOR / 2X500GB Seagates / 1TB WESTERN DIGITAL
    PCP&C Turbo-Cool 860 PSU
    SUNBEAM FAN CONTROLLER (3 120MM YL CASE FANS)
    DELL 2007FP MONITOR x 2
    HEATWARE Perfect (14-0-0)
    WATERCOOLED: 2 X MCP655 in Series, Thermochill PA120.3, D-TEK FUZION(Quad-Nozzle), MCW60, MCW30, 7/16" MASTERKLEER TUBING, 3 120mm YL FANS
    Xtreme Addict Exahertz's Avatar
    Dec 2006
    Maryland
    0
    I read that you can put silicon grase (or somthings) down inside of the pin's holes of the cpu socket. they say it helps seal it? but it looks messy.
    I think i saw this in a vapochill installition guide.
    Current System Build
    Designaton:" Rad Hat "
    __________________
    • Mother Board, RAM and CPU:
      Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
    • Graphics Processor:
      GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
    • Hard Drives:
      RAID: 2x 74GB Raptors on RAID 0 for OS Drives
    • Case and Power Supply:
      Case: Antec Case | PS: OCZ ProXstreame 1000W
    • Water Cooling:
      Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
    • (Water Blocks and Fittings):
      CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
      Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
    Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
    Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
    Last Updated 11/11/09
    Jun 2006
    0
    Quote Originally Posted by Exahertz
    dielectric grease is the stuff. i use it in my mounting to fill the voids under the cpu and i also use it in the void where the latch is.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    May 2005
    Virginia, USA
    0
    Yeah I was thinking about using it in the retension mechanisms gaps, but I had posted up earlier about using this brick of duct seal I have, think that would work?
    Jun 2006
    0
    if i was you i would buy the proper stuff to insulate not try to use what you have laying around. by my math you have killed $500.00 worth of high end equipment in a week and that is assuming your other stuff survived. plenty of online stores carry armaflex, conformal coating, dielectric grease ,neoprene and anything else you may need and it can be there as quick as your new motherboard. just my 2 cents i'm not trying to bust your bawls or anything.
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
    May 2005
    Virginia, USA
    0
    Nah man it's all good. I've already ordered a shedload of neoprene and dielectric.
    Dec 2006
    Maryland
    0
    ahh "dielectric" grease, thats the word i was looking for. yea we used that stuff to coat high voltage connections to our x-ray tubes (good up to 300 KVolts).
    __________________
    • Hard Drives:
    • Water Cooling:
    Banned Philly_Boy's Avatar
    Dec 2004
    Near Philly, Pa
    0
    Call Chilly1 when you get the chance. He'll help you thru this. . .
+ Reply to Thread
