What I was thinking of was after the water passes the rad, it goes into a secondary cooling stage powered by the TEC, to bring temps ever so slightly down below ambient. Condensation should not happen, because in the SF Bay area here, humidity is really low. I can't believe today temperatures outside dropped to 20F, because it like never does that here. Its getting chilly with the window open, but its good for my PC
I'm stupid I know. I was thinking putting the TEC there could help earn a few degrees. Just like 2 pretty weak ones sandwiching a block that will have water go through. I was thinking maybe I could do that when I finish my waterblocks, to use the leftover copper that won't get used anyways. Besides, weak TECs are like 40mmX40mm, so a block to cool them won't have to be too big. And a 120.1 rad should handle them.
