I know with mine as I don't have something to measure excat voltage but go by hearing, and the adjustabe dial on the Meanwell. The Rd30 gets pretty warm at full tilt. Doesn't take very long to get a majority of the bubbles out, but even running 24hours there will still be a little air, but the pump pulls 95% of the air out in the first two hours. Running of a seperate PSU was discussed to be more ideal as the pump is not meant to be switched on and off, so if one doea turn the system on and off quite a bit and the Pump is wired to the system PSU it would only negatively affect the Pump. Now running the pump on a seperate pump, especially with dialed voltage is taht you can turn it down when not running the PC. THer was a thread about the running the pump vs turning it off and I believe the majorty vote was to leave it running as that is how the Iwakis were designed.
Thats my .454634345c
I doubt any of use RD-30 owners would need to run 3/4 max of the 24, but I think someone is just because :-P.
