Results 1 to 11 of 11
Thread: R404a and low side pressure under load
    Mar 2003
    hey guy just wondering of any one knew or knew where i could find the proper low side pressure using r404 in a prommie under load. I think I need to add a tad bit more refridgerant because under load at 2.3 volts the evap temps drop drasticly and keep rising. yet under load on stock voltage I get may a 1-2 c rise in temps. If I remember correctly we saw about 0 on the low side before.
    Thanks in advance
    Bryan
    eocf newbs own, as does linx
    X.I.P.
    Oct 2002
    Australia
    0" was the low side pressure that I used too. I also have the same probs with holding the temp at really high heat loads.
    Dont know what the best value really is
    Mar 2003
    well i am gonna have him come out and fill her up while i put a 2.3 load on it and prime. I am gonna see here i guess
    Mar 2003
    well i am at -10in hg underloads and seems to be the ticket. who knows though
    Nov 2002
    Germany
    -10 ? What value do you mean ?
    I wana refill my prommy next week.
    cya
    XP2400+@2845Mhz Prommy chilled
    Jun 2002
    usa,va.
    cya
    he is refering to the high and low pressure reading of the compressor.
    -10 means the low side (suction side) of the compresser is pulling 10 psi of vacuum.so it would say 10in hg.
    Mar 2003
    does that sound right to you bowman?
    I know you know a tad bit about this stuff
    Jun 2002
    usa,va.
    well i am at work so i am only guessing.but -10 or 10 inches of vacuum with r404a should give evaperator temps of below -55c now that is the temp the freon is evaperating at...not the cpu or block temp
    Mar 2003
    yea you are corect my sig shows the evap load temp.
    Nov 2002
    Germany
    @ Rabeb25
    How much freon did you fill in or started with ?
    cya
    Mar 2003
    started with nothing, sucked it all out, ended up putting in.... who knows...heh
    sorry
    Bryan
