i have the same stepping as yours, so far i am 100% stable 8 hours at 3770mhz.
stepping L631B
vcore 1.45v
vmch 1.625v
vfsb 1.325v
vdimm 2.0v
As you may have notice, my load temps are starting to be a bit hot, the L6XXB stepped cpu are known for being really hot around and over 1.45v. I am on air cooling so with water you may use 1.6v but it would be the maximum i would use, im pretty sure your temp are reaching 65c load.
So anyway, youre overclock at 4ghz seems really unstable if it shutdows while priming. It is maybe because you are also reaching crazy temps and it safely shut down itself. When im at 1.5vcore i reached 75c while priming for 10 seconds and i stopped it.
I will continue to do my test, i am aiming for a 3850mhz 8hr + orthos stable under 1.5v around 70c load and a 4ghz + for benching at 1.5 - 1.55v
CPU Intel C2D 6400 - 6600 L631B Aircooled 4010 MHz (wip) 3850 MHz daily
COOLER Big Typhoon 120 - Ultra 120/Panaflow 103cfm
MOBO Asus p5w dh - Badaxe 2
RAM 2gb Team 667 cl3 844mhz 4-4-3-4 2.0v (wip)
GPU Bfg 7900GT - XFX GX2 600/1600 3Dmark06 10554 (wip) 207K AM3
PSU Gamestream 600w - Powerstream 520 - Silverstone Zeus 750w
Chassis Lian-Li V2000b Plus2 Lian-Li v1100b
- You may not post replies
- You may not edit your posts
Forum Rules
