In-depth Brisbane Review
Anandtech
Anandtech Review gives us some new, unheared of info about K8 65nm:
* Uses the same integer Memory Divisors. This means that the odd Multipliers used for archiving 100 MHz increases can result in even slower Memory Frequency that the even ones.
* Cache L2 Latency increased from 12 clock cycles that all the K8s from initial launch until now had to 20 clock cycles (Remember Prescott to Prescott 2M?). This is the cause for the slighty slower performance on some Benchmarks on the Preview.
* From Anandtech test samples, 65nm Energy Efficient A64X2 4800+ and 5000+ works at 1.35V while the older Windsor 90nm full power A64X2 5000+ works at 1.3V. Smaller manufacturing process but higher Voltage??? However, power consumption is lower anyways, but it should have been better.
It isn't surprising right now that AMD is releasing the DH-F3 and JH-F3 parts that I commented some time ago for their highest end Processors when the 65nm ones scalability AND performance is crippled. AMD, what the hell are you doing?!?!
Source: Anandtech
