We are happy to announce that wPrime, an new benchmark application that takes full benefit of having a multiplecore processor, has been added to the hwbot benchmark suite.
wPrime has the same ease of use as SuperPi, but has 4 key benefits:
- multithreaded: take full use of your dual / quad core processor
- simplified: click 32M for a quick test, 1024M for a stability test. No 10 different methods to choose from.
- hwbot integration / one click comparison: no need to manually enter your result on hwbot, or post it in a bot monitored forum. Just click ’submit’ and you can compare your result to ten thousands of other overclockers. If you belong to a team which uses a bot to monitor your forum, the bot will will update your forum ranking too.
- hardware recognition: in contrary to superpi, wPrime dedects your hardware automatically.
The current version is v1.28. Previously submitted results by beta testers with a client < 1.27 will be deleted.
- original anouncement
- download wprime v1.28: local - mirror
- wPrime info page
- wPrime website
- 32M: hall of fame - statistics
- 1024M: hall of fame - statistics
- hwbot forum discussion
Known issues:
- checksum validation sometime fails on hwbot
- if you submit another result without closing your browser window first, your browser may display cached data. Hit CTRL+F5 if you encounter this issue, or close your default browser if you submit a second result.
