Is there any sound card that actually inproves the quality of mp3.
||Asus P5B||Celeron 420 320*8||1GB RAM||Samsung 24IN LCD||Seti@HOME||
||XFX 680I LT||No CPU||2GB RAM||Seti@HOME||-Down
||PSP||PS3||Wii||iPhone||Mac Mini||LCD-TV||2-LAPTOPS||Z5500||
SB X-Fi Xtreme Music!
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
This actually inproves mp3 quality.SB X-Fi Xtreme Music
http://www.custompc.co.uk/custompc/r...eme-music.html
I have one, and now hate listening to my mp3's on my other machine
Chaintech AV-710 > http://www.newegg.com/Product/Produc...82E16829120103
Seriously. It's amazing. Just use the Via Vinyl 500b drivers instead of the ones that came on the CD, and it'll be the best $30 you've ever spent.
I'm going to be getting the best sound card w/ breakout in existence, soon.
TerraTec Aureon 7.1 Universe
It'll work in linux, and in windows, it's made with some of the best components (the breakout box could be better shielded, but I think I can come up with a solution to that), and unless you're a music producer or an extreme gamer, it has everything you could ever need. 8-channel output, input enough for any mildly curious enthusiast, and digital outputs for if you lean that way.
For good non gaming audio it has to be either terratec or chaintech.... you definitely do not need an xfi if you're not in it for gaming sounds.
FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
eXceed TJ07 worklog/build
So these sounds cards, can also improve mp3 quality.
Er...you can't improve mp3 quality, sorry to break it to you. Almost ALL sound cards are able to deliver the "heart-pounding" 128kbps with no problem, so one won't sound better than the other.
For better sound quality, download better MP3s (192+, V0, etc.) THEN you can look to fine tune it with a good soundcard.
