And here is some interesting resaults with memory unlinked and diferent speeds/timmings
Are you using the G.SKILL HZ ram?Originally Posted by Phil The Greek
Can you post some feedback about the sound and especially sound crackling / poping issue ?
Do you have sound issue with your mobo ?
Bios 505 perhaps solve the problem but I'm not sure.
I have P5N32-E SLi nF680 bios 405 and I HAVE THE SOUND ISSUE.
Just ordered a Striker but scared about sound :/
I never use onboard sound so i cant help you there.Originally Posted by noobzed
I see: X-Fi sound card in your sig.
Do you have issue with this sound card ?
I think you don't run SLI :/
No problems here, but yeah im not using SLI, i think you should be fine even with SLI.Originally Posted by noobzed
runnining SLI with no problems here
Can anyone else confirm the memory bandwidth loss at anything over 1600fsb , ive run everest cache and memory test and Sandra and i lose alot of bandwidth when running 1600+fsb
here at 1700FSB vs 1600FSB you can see a 1000mb/s difference in memory read in everest and latencies have increased slightly. The difference get even worse the higher you go at 3600mhz its horrendous latencies jump to 78 and mem read goes to 10000.
http://img510.imageshack.us/my.php?i...benchedbr7.jpg
http://img223.imageshack.us/my.php?i...benchedyr8.jpg
Q6600 GO @3.6Ghz 1.45v
Crucial Ballistix PC8500 1200mhz 5-5-4-7@ 2.2v
BFG 8800GTX OC @ 625/2000
Gigabyte GA-P35-DQ6 F3
Swiftech H20-premium
Thermaltake Armor
Ultra X-Finity 800w
Sharp Aquos 37" LC37GP1U DVI-D 1920x1080 6ms
Logitech Z-5500
Xi-Fi XtremeGamer Fatal1ty
man pedro, how did you get that RAM?
Thats sick stuff man! Its sooo freakin, GOLD! LOL
Yeah nioce stuff bro, man... wow!
Intel E2140 @ 3.2ghz Lapped
TT Big Typhoon Lapped
Asus P5K-C
2gb OCZ Gold ddr2 800mhz
8800GTS 320mb
with super clean 2k3
I looked at your pics of everest memory read a 3-3-3 1t and i find them actually quite low, i mentionned earlier in this thread about memory bandwidth loss at FSB over 1600.
Look at at my memory read in the link below and im running @ 4-4-4-12 1T@800 with 2.1v
http://img212.imageshack.us/my.php?i...444121tox7.jpg
Thermaltake Armor
Ultra X-Finity 800w
Logitech Z-5500
FYI, B1 stepping core2 have lower reported everest bandwidth than B2 stepping clock for clockOriginally Posted by Synicalcop
Ok perhaps there is a difference between b1 and b2 stepping in memory bandwidth, i dont think there can be a 6000mb/s difference when he's running ddr2 900 at 3-3-3 1t, im scoring 17k at ddr800 4-4-4-12 1T and he's scoring 11-12k at 4.2ghz something is quite wrong there. In know way am i trying to jack this thread i just wanna be sure his system is running 100% he should be hitting about 20k if not more in everest memory read.
Thermaltake Armor
Ultra X-Finity 800w
Logitech Z-5500
My L631B cpu initial testing at 3.6ghz, realised core temp and probe reads about the same temps. Idle 33deg, load 54deg in a 29 deg room.
1.2v HT = 1.45v, NB = 1.4v, Vdimm = 2.32v all others set to auto.
http://support.asus.com/download/dow...iker%20Extreme
Link to new official 0505 bios
says 302 latest official on that link ?Originally Posted by noobzed
Iceflight, try small ffts and see what coretemp vs pc probe2 temps are like
In small ffts, and I'm trying without the air con now, coretemp seems to report lower than the probe now, coretemp=60deg, probe=63deg.
weird must be B2 diff from B1 steppings
@3600Mhz - 9x400FSB at 1.39v
On Asus 680i Striker Extreme it seems 3600Mhz handles fine at 1.39v vcore under load so far. I used 2x512MB OCZ PC5400 Platinum XTC 3-3-3-12 memory for the tests.
Settings used:
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1600 (means 400FSB)
Actual FSB (QDR), Mhz: 1600
MEM (DDR), Mhz: 800 (means 400mhz speeds)
Actual MEM (DDR), Mhz: 880.2
Vcore Voltage: 1.525 set (1.42v bios/1.41v windows idle/1.39v windows load)
Memory Voltage: 2.100v
1.2v HT Voltage: 1.3v
NB Core Voltage: 1.4v
SB Core Voltage: 1.55v
CPU VTT Voltage: 1.4v
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
tCL (CAS Latency): 4
tRCD: 4
tRP: 4
tRAS: 12
Command Per Clock (CMD): 2 clock (2T)
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
Prime95 v25.1 multi-threaded dual small FFTs priming for ~1hr 18mins before I stopped it. Interesting that even coretemp reported cpu temps fluctuated alot more jumping between 59C to 68C while priming.
Post Prime idle temps:
Asus PC Probe2 reported voltages vs Digitech QM1538 Digital Multimeter measurements while under load @2400mhz at 1.3875v bios set (1.28v vcore idle / 1.26v vcore load).
+3.3v rail = 3.26v vs 3.387v real
+5v rail = 4.78-4.89v vs 5.02v real
+12v rail = 11.78v vs 12.23v real
Originally Posted by eva2000
There is a new official bios for the Striker mobo, the 0505 one, do you see that file or not ?
you guys think rd600 is going to do better than this? because $433 on this board isnt worth it. rd600 FTW or asus 680i FTW ? or something else... hows the max fsb on this board?
nope don't see it on that link.. says latest is 302Originally Posted by noobzed
So @ 3600MHz and DDR2 1200 this board is a hair slower than mine in pi1m and a full minute faster @ pi32m. Interesting.
Well for me it says 0505, maybe you need to refresh your browser. It's there.Originally Posted by eva2000
