I plan on switching and need help with some parts. The money is not really an object but don't want to use any TEC's and would like to cool the cpu, NB, and Gpu. I live in Canada so i'm limited by what I can buy so I'll list the choices I'm considering....
CPU BLOCK-
DangerDen Maze 3
Swiftech MCW5000A
Silverprop Evolution
D-tek custom or spiral
GPU BLOCK-
DangerDen for Radeon
Swiftech MCW50
CHIPSET BLOCK-
DangerDen Z-chipset
D-Tek fsb NB cooler
Radiator-
D-Tek Pro Core combo
BIX rev 2
PUMP-
Ehiem 1250
Hydor L30
RES-
Bayres
Criticool water plant
DD clear
If possible I would like to keep the blocks similar, and would like to see if I could get one to fit in my turbo gamer (chenming) case. I might have a problem seeing as I'll be running 3 hd's and 1 floppy and i'll probably have to remove the bottom drive bay so I don't see how it's all going to fit. I have also considered getting a Lian-Li pc75 case for all this and using my current case for another system.
