Here is my latest creation. I had to change to plan-B since lack of proper lathe blades but im pretty confident this heavy thing will perform quite well. Container still havent got that finishing touch but here it is anyway:
Still that copper junk inside but im too tired to clean it now..
Holddown will be on top of the container.
Diameter is 80mm and height 200mm. I could lighten the container pretty much by latheing material from outer diameter (~8mm -> -1,5kg).
Ill propably finish it next weekend but im thinking about using it in the 160w heatload tester already before that.
edit. weight is now 2720g
