+ Reply to Thread
Results 1 to 3 of 3
Thread: Celeron M - P4p800se Fsb Problem..
    Xtreme Enthusiast hey's Avatar
    Oct 2005
    istanbul/Türkiye
    0
    Hi , i have fsb problem with my celeron m ,, i m using ct-479 with p4p800se ,, its fully prime stable @ 167*15=2513mhz ,,but freeze @ 168*15..,at170*15 it completely shut down and need clearing cmos.. ,,, i tried everything,,increase vagp speed-voltage,cpu vcore ..vs ..but it s like it locked at 167mhz..did i miss sth.?? my bios is 1012beta..
    The un-extreme XIP cirthix's Avatar
    Jul 2004
    0
    have you modified the ct479?
    set your vcore to around 1.5v actual
    clockgen results?
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Oct 2005
    istanbul/Türkiye
    0
    479 ct un modded
    clockgen doesnot works system hangs at 168
    tested cpu voltage and it doesnt work ,, it s like locked @167..
+ Reply to Thread
