sorry, by "lower" I meant "looser" , that means from 6ns that you have set it to 7 and double check your voltage settings, dont use auto voltage! To be sure, give the chipset abd LDT little more juice and start with a safe setting on the cpu and a try to find the max of your ram, double check your dividers and stuff ... than do it the other way around, for memory stability use memtest for windows to at least 400% coverage, 1000% to be sure and for cpu stability go for StressPrime Orthos beta, good luck
