Results 1 to 6 of 6
Thread: Transmit Error?
    Da Goose
    Oct 2005
    Chicago
    Transmit Error?
    This GPU hasn't been able to upload since last night...several hours. Is this normal ? Will it fix itself ? I know for a fact my internet works, I am posting to this forum...
Name:	xmit error.JPG
    i7-860 Farm with nVidia GPU's
    Xtreme Cruncher
    Mar 2006
    UK
    Hhmm, can't check my GPU folder at the moment, but I can ping both the WU servers from here & http://fah-web.stanford.edu/serverstat.html says they're both up...
    Try exiting the client & restarting it. If that doesn't work you could add -send all to your shortcut & see if it will force an upload
    Mar 2006
    Before i started my gpu console window i allowed it in my firewall, i use kaspersky. Other than that, i'm stumped
    Nov 2006
    UK
    I had a similar problem , it looks like you selected yes to the 'use ie settings' question during your config ,
    Stop the service , open a dos window and cd to the gpu folder and enter -
    FAH5.05beta1-console.exe -local -configonly ( answer 'no' to the above question restart the service ).
    it worked for me
    Wandersome Cruncher
    Apr 2005
    England
    Did a new unit get downloaded?
    If so, I would imagine the completed unit will upload when the server for that unit wakes up.
    Servers going offline for a while is pretty common.
    My gpu returned a unit ok at 7am U.K time.......if your gpu has work to be getting on with in the meantime I wouldn't be too concerned.
    Checking config settings as noted above is a good idea though
    Visit The Boinc Bar Today
    Boinc Boinc......The first 50 mil is the hardest!
    POEM U.K number one.....woot
    Da Goose
    Oct 2005
    Chicago
    It fixed itself...Why would I NOT want to let it use IE?
