!st I hope this is the right forum for this![]()
I cannot boot my system with Hyperthreading disabled i get a blue screen with this on it.
A problem has been detected and windows has been shut down....DRIVER_IRQL_NOT_LESS_OR_EQUAL
Stop:0x000000D1
when i enable Hyperthreading my system boots normally.
As for the Windows error message.. I know that can a number of different things...and after a bit of Googling, apparently these two files get added when Hyperthreading is enabled.
- halmacpi.dll
-ntkrnlmp.exe
So i'm thinking that these are causing the fault...(guessing) but don't know if its safe to remove them.
P4 3.4Ghz prescott
Gigabyte GA-8S661FXMP-RZ
GeForce FX5200
Wd 160Gb HDD
Seagate 120Gb HDD
LG 16x burner
Lite-on DVd rom
1Gb Generic DDR 3200
The reason i want to turn it off is i read that the cpu runs cooler with it disabled..mine is idleing at 52c.but jumps upto 75c and above when using applications like photoshop.
So is there a way to disable it and be able to boot without doing a re-install. If I disable it in the BIOS, then do a Repair with the XP pro CD, would that work..As you can probably Guess i'm a bit of a NooB at this.![]()
cheers
linuts
The PC will not run that much cooler, but it will definitely "feel" slower and not as responsive... How about just gettinhg a better heatsink... You can get $20~30 aftermarket coolers that will shave 10~15deg off your temps... That would be a logical thing to do...
