I am getting errors one of my computers.
Take a look at the screenshot.
Many invalid Wu's
I just rebooted the computer (but I doubt it will help)
Anyone have an idea what this means?
I could try to remove & reinstall the boinc client.
Many invalid Wu's
Hmm I never saw that error, but I would suggest to remove the whole folder and install BOINC again and dosnload new WUs.
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
I had the same problem on one of my DX rigs that used to run Rosetta with BOINC 5.4.9 and the 5.5.0 optimized client. Replaced the client with the standard 5.4.9, switched to WCG, and started getting computation errors. Tried lowering the OC, no good. Then I replaced 5.4.9 with 5.4.11, and started getting the same error message you are getting. Finally did a repair install of XP, uninstalled BOINC, deleted the residual folder, and reinstalled BOINC 5.4.9, and it's now error free. What a pain that was.
I would uninstall whatever version of BOINC you are running, remove the BOINC folder, then reinstall BOINC 5.4.9. If that works, you will save yourself the repair install of the OS.
DDTUNG
XtremeSystems - we overclock and crunch you to the ground
I left the optimized files on three 3GHz P4 HTs. Ban me.
DDT, I followed your advice.
Did a windows repair and reinstalled boinc.
thanks for the advice
