Hey guys,
What is the AVERAGE overclock people are getting on the 6400 Core2 chips?
Any Ideas?
Thanks,
OPP
Hey guys,
Any Ideas?
Thanks,
OPP
I guess around 3.4 to 3.5GHz.
Had two E6400 (L625A and L628A) which both did 3.6GHz (1.41Vc/1.46Vc).
I think the L625 could have reached 3.7+ but my board didnt even boot @ 454FSB.
raiden
Is that stock cooling (air) ?Originally Posted by Raiden Zero
OPP
3.1 ~ 3.5Ghz air to single stage.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
As an average...i would say 3.4GHZ with up to 1.4Vcore and the stock Intel cooler.
Asus Rampage IV Extreme ==> i7 4930k @4.9Ghz water-cooled (3325A911) IMC 3400+
Asus Maximus V Gene ==> i7 3770k @4.8Ghz air-cooled (L224B652) IMC 3100+
VTX3D 7870 Black Edition
Avexir 2666 CL-11
Enermax Revolution 85+
~3.2GHz @ 1.5V - on stock intel cooling
~3.6GHz @ 1.5V - on TT BigTyphoon / Tower120 etc.
~4.1GHz @ 1.6V - under vapo
~4.4GHz @ 1.65V - under DI
Nah, Scythe infinity =).Originally Posted by OPPAINTER
On stock... 3.2-3.3GHz
raiden
3.73GHz on air for me. I would say the AVERAGE (heavily dependent on user skill) is only about 3.2-3.4Ghz. You should be able to take them to 3.7-3.8Ghz stable on air. 4.0 on water with A LOT of volts. 4.2 or greater on SS.
3750 with Zalman 9500 for me.24/7 speed I used is 3.4Ghz,1.425 v-core.
@freecableguy: what is SS,dude ?..Originally Posted by freecableguy
OPP-
Besides your post in your own birthday thread, this is the first time I've seen you around here in awhile. Now before you leave, someone needs to force an X6800, two 8800's and a new mobo onto you and make you bench some... It's weird seeing you quiet for so long when all this new BAD@ss hardware needs benched to death
Do what you love, Love what you do.
@911us-
Single Stage Phase Change I take it
Thanks for the info guys.
I was just checking this chip at work on water and it does 3.6 rock solid 1.46V. I have not tryed overclocking it any higher because it's on the bench right now and I am going to put it into a case. Once it's in the case I'll go max stable OC. I just was wondering if the chip was any good before I put it in the case. I think it has potential
OPP
Originally Posted by makatee
Yea I have no hardware. I would like to get some G80s and bust out some scores, but my friends at NVIDIA slacking on me
OPP
My beloved week 24 E6400 did 3.6GHz @ 1.5V (real) on water.
Until it... err...
...went away...
You were not supposed to see this.
My crappy E6400 does 3830mhz max superpi 1m on air 1,725V
On stock volt it can't even do 3200mhz
If you're lucky you could do 3500mhz on 1,4V stable
My Rig:
Intel Core 2 Duo E6400
2x512mb Micron PC3200 OEM D9DQW "Fatbody"
Biostar TForce P965 Deluxe
MSI/Medion GeForce 6700XL (Cheap )
Chieftec 360W (in search for someting better)
WD 160GB S-ATA
isnt this entirely dependant on motherboard????
for instance, a P5W like mine which FSB walls @ 378 for some reason, that kind of limits where you can go..
Anyway, I'd say ~3.3 is average.
Good Luck OPP! Wanna come do some WCG
Originally Posted by largon
so how much you set in bios.
Stock cooler I'd say 3200-3400 average (stock cooler really sucks). Better air or water more like 3500 average for 24/7 stability.
MB Reviewer for HWC
Team OCX Bench Team
Bail_w,
IIRC, bios was set at 1.525V. DMM measured voltage was 1.506V
The E6400 I tried did 3.2 on stock volts, 3.5 Orthos blend stable, and could be benched @ 3.7 on a P5B deluxe wifi. By benched I mean 3dmark06, and other such things. 3.7 was not it's 24/7 speed, 3.5 was.
id say they are all over the place between 3.3- 3.8ish
mine runs 24/7 1.5v 8x450 on air and will bench upwards of 4040mhz... on air.
mine does 3.6GHz 24/7 on air but today I went down to 3.4GHz on my E6400 so I could run my memory at 530MHz (5-5-5-12 4now) and I can deal with a lower CPU clock and a high memory clock seems good for BF2142 and my BFG 8800GTS
