[11/13/2006 10:37:59 PM] Start init node...
[11/13/2006 10:37:59 PM] Loading webserver config from: F:\mj12node_win32_v130\webserver.xml
[11/13/2006 10:37:59 PM] Init: trying to connect to database...
[11/13/2006 10:37:59 PM] Init: connected to database!
[11/13/2006 10:37:59 PM] Init: running base SQL...
[11/13/2006 10:37:59 PM] Init: running base SQL done!
[11/13/2006 10:37:59 PM] Init WebCrawler...
[11/13/2006 10:37:59 PM] HKom is DISABLED in this release
[11/13/2006 10:37:59 PM] Using COM call to change max-threads!
[11/13/2006 10:37:59 PM] Maximum workers: 200, set threadpool to: 200 (was: 200), IO threads: 1000 (was: 1000)
[11/13/2006 10:37:59 PM] Cleaning database
[11/13/2006 10:37:59 PM] Starting main threads
[11/13/2006 10:37:59 PM] MJ12bot/v1.0.8 (
http://majestic12.co.uk/bot.php?+) started with 200 workers.
[11/13/2006 10:37:59 PM] done!
[11/13/2006 10:37:59 PM] Finished init node...
[11/13/2006 10:38:05 PM] Could not get URL via HTTP:
http://www.majestic12.co.uk/projects...de/banlist.txt Error: System.TypeInitializationException: The type initializer for "System.Net.HttpWebRequest" threw an exception. ---> System.Configuration.ConfigurationException: Unrecognized attribute 'useUnsafeHeaderParsing' (F:\mj12node_win32_v130\MJ12node.exe.config line 7)
at System.Configuration.HandlerBase.CheckForUnrecogni zedAttributes(XmlNode node)
at System.Net.Configuration.NetConfigurationHandler.C reate(Object parent, Object configContext, XmlNode section)
at System.Configuration.ConfigurationRecord.EvaluateR ecursive(IConfigurationSectionHandler factory, Object config, String[] keys, Int32 iKey, XmlTextReader reader)
at System.Configuration.ConfigurationRecord.Evaluate( String configKey)
at System.Configuration.ConfigurationRecord.ResolveCo nfig(String configKey)
at System.Configuration.ConfigurationRecord.GetConfig (String configKey)
at System.Configuration.DefaultConfigurationSystem.Sy stem.Configuration.IConfigurationSystem.GetConfig( String configKey)
at System.Configuration.ConfigurationSettings.GetConf ig(String sectionName)
at System.Net.HttpWebRequest.GetDefaultMaximumRespons eHeadersLength()
at System.Net.HttpWebRequest..cctor()
--- End of inner exception stack trace ---
at System.Net.HttpWebRequest..ctor(Uri uri)
at System.Net.HttpRequestCreator.Create(Uri Uri)
at System.Net.WebRequest.Create(Uri requestUri, Boolean useUriBase)
at System.Net.WebRequest.Create(String requestUriString)
at Majestic12.Utils.GetURL(String sURL, String p_sTargetFileName, String sUserAgent, Boolean bWriteAsBarrel)
[11/13/2006 10:38:05 PM] Failed to get fresh ban list: System.Exception: Could not get file via HTTP! ---> System.TypeInitializationException: The type initializer for "System.Net.HttpWebRequest" threw an exception. ---> System.Configuration.ConfigurationException: Unrecognized attribute 'useUnsafeHeaderParsing' (F:\mj12node_win32_v130\MJ12node.exe.config line 7)
at Majestic12.Utils.GetURL(String sURL, String p_sTargetFileName, String sUserAgent)
at Majestic12.WebCrawler.UpdateBanList()
[11/13/2006 10:38:11 PM] Got response: Busy try later
11/13/2006 10:39:11 PM] We are in starvation mode but we will try again since 60 seconds elapsed since last check: 11/13/2006 10:39:11 PM - 11/13/2006 10:38:09 PM
[11/13/2006 10:40:12 PM] We are in starvation mode but we will try again since 60 seconds elapsed since last check: 11/13/2006 10:40:12 PM - 11/13/2006 10:39:11 PM
[11/13/2006 10:40:30 PM] Could not get URL via HTTP:
http://majestic12.kicks-ass.org/data...F30A85BE284.gz Error: System.TypeInitializationException: The type initializer for "System.Net.HttpWebRequest" threw an exception. ---> System.Configuration.ConfigurationException: Unrecognized attribute 'useUnsafeHeaderParsing' (F:\mj12node_win32_v130\MJ12node.exe.config line 7)
[11/13/2006 10:40:30 PM] Failed to get new URLs: System.Exception: Could not get file via HTTP! ---> System.TypeInitializationException: The type initializer for "System.Net.HttpWebRequest" threw an exception. ---> System.Configuration.ConfigurationException: Unrecognized attribute 'useUnsafeHeaderParsing' (F:\mj12node_win32_v130\MJ12node.exe.config line 7)
at Majestic12.WebCrawler.CheckForMoreURLs()
[11/13/2006 10:41:13 PM] We are in starvation mode but we will try again since 60 seconds elapsed since last check: 11/13/2006 10:41:13 PM - 11/13/2006 10:40:12 PM
[11/13/2006 10:42:15 PM] We are in starvation mode but we will try again since 60 seconds elapsed since last check: 11/13/2006 10:42:15 PM - 11/13/2006 10:41:13 PM
