Results 1 to 3 of 3
Thread: Help me decide between DFI Expert and Venus
    Mar 2005
    Denmark
    My k8n neo4 has decided to stop working and I need a new motherboard for my main computer. Right now I have a DFI LANPARTY UT nF4 Ultra-D in my main rig that I'm going to put in my secondary rig, so I am looking for the best oc motherboard for my primary computer (see rest of specs in sig). I can't decide whether to buy the DFI Venus or the DFI Expert. Can anyone tell me what the difference is between these two, and if one is a better oc'er than the other?
    Tia
    Rig 1: DFI Lanparty NF4 SLI-DR Venus / Opteron 170 @ (Watercooled: Storm, Laing DCC Pro, Termochill PA 120.2 with 2x120 pabst) / G.Skill Extreme Series F1-4000USU2-2GBHZ (Samsung UCCC + Brainpower PCB), / ASUS Extreme EN7900GT/2DHT w/ZALMAN VF900-Cu cooler / Enermax Galaxy 850w/ WD 74GB Raptor / WD 300GB / Maxtor 300GB / Seagate 80GB / NEC 3500A DVD-RW dual layer / Thermaltake Mozart TX.
    Rig 2: Under construction...
    Xtreme Recruit
    Mar 2005
    Good luck on finding a Venus,limited production MB of which 1000 were made.
    It's basically an Expert,but w/nice presentation case and will command a used price generally higher than a new Expert
    You probaly won't see much of a higher OC w/Expert/Venus over a Ultra D,in fact a mate just switched from a Sli-D to Expert and OC went down,YMMV depending on hardware
    Nov 2005
    Chicago, IL
    Here are some pics and info on the Venus
    I would stick with the Ultra-D, probably wouldnt see a performance gain for the money spent.
    Asrock Z68 Extreme4 Gen3
    •i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
    •G.Skill F3-12800CL9D-8GB
    •ASUS 7850 @ 1250//5800
    •Corsair TX650 V2
    •Dell 3007WFP
    •Win 7 64 Ult
