ahh, might take a few more of us to do that..The guy can do 30mil a day by himself!Originally Posted by Mc Intosh
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Movieman
Yeah, he's one sick puppy...
Running @ AMD 64 X2 4200+ & AMD 64 3400+
That's OK, I have plenty of competition right here to keep me busy today..Originally Posted by Mc Intosh
Some gentleman from a country surrounded by water..
My goal is to, almost single handedly, get Scotland in top 5 producing countries for a day or two
Is there any way to force MJ12 to do _more_?
It's not even coming close to taxing my bandwidth.....maybe it's a VM issue?
That's easy! Whats your login/password!Originally Posted by Mc Intosh
Any country that can produce a William Wallace deserves to get to the top of the heap!
Ghe, I think i can handle The Germans (nofi ) on my own.Originally Posted by Movieman
First place would be impossible, since some dude from Malaysia has it occupied...
Drat: Where did you download that V 1.3.5 Beta. All I have is the freaking V.1.3.0
I feel deprived ....
Space for Rent
Originally Posted by Jose
http://majestic12.co.uk/files/mj12no...et2_v135b3.zip
Have you tweaked any of the clients settings yet? If yes then you may have to run more than one client to get the max out of it especially if it's that line you posted an SS of .Originally Posted by Vapor
Also what kind of success % are you guys getting with the new client? I used to be able to run 130 workers and 50 buckets and get about 60% success with 1.3.0 now with the new beta i get about 30%
UPDATE: It's now getting; 9% sucess, 82% timed out, but it has also crawled a total of 30K in 12 mins, my lines only 2mbit .
Yeah time-outs percentage is very high... don't understand...
Crank that bad boy up! I'm coming for you!Originally Posted by Mc Intosh
http://www.majestic12.co.uk/projects...fo.php?id=1021
I spent a little time browsing the forums over at MJ12 and apparently MJ12 and Boinc sometimes have trouble working together. I installed the 1.3.5 beta and it was responding the same way as 1.3.0 until I turned off boinc for a few minutes, then computer started to chew through URLs, pulling in nearly ~1200 urls every minute. I then changed the priority of MJ12 to be above normal on all attributes, restarted boinc, and the system is happily crunching away. I've also got a 93.5% success rate after 25 minutes into a crawl, if anything changes I'll update. Yay beta + priority tweaks!
JC.... can't keep up i'm afraid....Originally Posted by Movieman
You'll be pushing towards 8-9 mil.
Originally Posted by gomeler
Ah you were runnning a BOINC project next to it.
I've got these 2 machines dedicated to MJ12, would produce far less if I ran a BOINC project next to it.
If I hit 8-9 million we'll all be happy!Originally Posted by Mc Intosh
I also have WCG running 4 WU each on both of those machines.
MJ12 used to use 0% CPU usage with boinc and previous settings, now it is up to about 1-2% on a 2.8GHz E6400. I won't be hitting movieman speeds but it's still doing a good job crunching through the URLs, much better than before. Now it is time to do some school work, can't tweak crunchers for money
Argh..I did as I was told and yet I dont get the Beta installed.... sniff
Space for Rent
Yeah, fully tweaked....can't sustain more than 10mbps, but only averaging 7ish mbps....I can go download or browse with no slowdown at all....won't use more than ~20 buckets and ~140 workers. The system is dedicated to MJ12 as welll....nothing else running. I get 50% better results running native than I do on a VM. Running 2VMs gets worse results than running 1....but I have a feeling that's a system limitation (Kernel was using a core to itself somehow....with no apps running, maybe OSX was bugging out with a new MySQL install, who knows).Originally Posted by melymel2789
When I left this morning (after just upgrading to 1.35b3 and going native XP), I had something like a 65% success rate and did ~105k in its first 33 minutes of being active.
I have changed back to .NET library crawling...
I'll let it run for a day to see what difference it makes...
Yesterday and today around 5.5 mil. urls... (MJ12 stats)
Let's see what tomorrow will bring...
Great updates team...I'll be joining up to help out again starting this weekend. Melymel, did I give you a big enuf lead?
i7-860 Farm with nVidia GPU's
I just found out where Vapor joined up! Kept looking for his name today!
XSTM is going to have to change it's name to XS the Country!
Yeah....IDK how I ended up on XSTM, I put in all the info for XSCM
Still sorting out the issues with the node limit (seems 8mbps is about all it can average....), should be able to get a second machine up to allow more bandwidth usage sometime soonish....
Also working around the starvation mode problems....ugh. Also working around the fact that I can't get it to run on OSX without production killing VMs and XP isn't even good at sucking a nut and is a pain to use.
I also have problems with the fact that my school really really hates people using routers, killing bandwidth to anybody that does, so no wireless or desktop internet for now.
Let me give you the right login info for XSCM:Originally Posted by Vapor
Email: Davidd......
Password:
Hey Guys! We picked up over 23 MILLION on Norway just today!
Great going to all!
CorrectionOriginally Posted by Movieman
When the machine gets hot, your correct setting wil be......
Password
~Opinion about Dogs~~~~~~~Hug~~~~~~~~
________________________________________________
