need custom bios for GA-965p S3
hi all i need your guys help i need a higher multi on this mobo for my e6300 i can select 6-7 but i need higher so i can overclock more without maxing out my mem
anyone up to helping thanks SAM...heres the bios
http://www.gigabyte.com.tw/Support/M...ProductID=2321
hope the link takes you to the bios if not go to download and click on bios then GA-965p-S3 mobo and it will be F6 bios thanks
edit= i would have done it but i cant find any modbin6 that will work under windows xp pro
no amount of bios mod is going to help you get higher then 7x multiply. E6300 can only go up to 7x max. You want to overclock more change then your ram ratio down to 1:1, if you haven't done so, otherwise you need to get better ram.
well crap i need better ram i got ddr2 667 but guess i need ddr2 1066 thanks for your help
- You may not post replies
- You may not edit your posts
Forum Rules
