PCMark 2005 Ranking
PCMark 2005 is a popular benchmark application to measure processor / memory / harddrive performance.
download here
Rules
- don't use multiple nicknames
- only post scores belonging to you
- leave everything to default
- include a screenshot or a futuremark compareurl of the result
Guidelines
- format your score as follows: [hwbot] score - system description [/hwbot]
- try not to use abbreviations. eg. 'opteron 146' is ok, '146' is too short.
- format processor overclock like 'A64 3200+ @ 2850Mhz' or 'A64 3200+ @ 2.85Ghz', format videocard speed as 'R9800 @ 350/333Mhz'.
- allowed score formats: '12345' or '12345 marks'
- don't use text layout (bold, italic) or hyperlinks in your system description.
bot info
moderators: FUGGER
members who changed team: ncsa (i4memory.com), muzwa kai (Overclockers Australia (OCAU)), fearthisneo (EXTREME Overclocking), IntelGuy (PC Pitstop), cadaveca (no team)
options: update ranking now
team ranking - hall of fame
rank - top 10 average - team name - weekly & monthly rankchange - links
1. 27487.50 PURE - ~ ~ - website
2. 26223.20 Bench Tec UK - ~ ~ - website - forum
3. 26090.90 H.O.T. - ~ ~ - website - forum
4. 21724.50 i4memory.com - +1 +2 - website - forum
5. 21410.00 Madshrimps Belgium OC Team - -1-1 - website - forum
6. 21174.40 XtremeSystems - +1 +1 - website - forum
7. 20991.90 OutOfSpecs.Gr - -1-2 - website - forum
member ranking - hall of fame - more
- 1. pro (Team Australia) - 32397.00 - GIGABYTE X58 UD4P, Sapphire VAPOR-X 4890 @ 1050/1100, 4x Gigabyte I-RAMS, 4x SSD (GSKILL Falcon/INTEL X25M), 2x DDRDRIVE DDRDRIVE.COM, ADAPTEC 5805 and CORSAIR 2000 C7 + CORSAIR HX1000!
2. AndreYang (PURE) - 31292.00 - 1*Acard and OCZ SSD tested. GA mobo is good for PC mark05.
3. hipro5 (H.O.T.) - 30609.00 - Not bad....I'll keep on.... :o)
1. justin.kerr - 24902 marks - Core i7 920@4803mhz - no description
2. loonym - 24902 marks - Xeon W3520@4470mhz - no description
3. Jor3llBR/Elano - 23758 marks - Core 2 Q9650 (3Ghz)@4930mhz - no description
4. mkultra - 21578 marks - Xeon W3520@4524mhz - no description
5. FUGGER - 21097 marks - Core 2 QX6850 (3.00Ghz)@4849mhz - QX6850 @ 4849MHz - 8800U @ 750/1250
6. Francis69007 - 20421 marks - Core i7 Extreme 940@4433mhz - no Iram Here => just Raid0 on 4 SSD 7535 Mtron pro / Ich10 Controler
7. jcool - 20109 marks - Core i7 Extreme 975@4500mhz - no description
8. Linuxfan - 19754 marks - Core i7 920@4503mhz - Single OCZ Vertex... RAID 0 coming soon!
9. pedrorocha - 19562 marks - Core 2 Q6700 (2.66Ghz)@4600mhz - no description
10. sson74 - 15661 marks - Core 2 X6800 (2.93Ghz)@4920mhz - no description
11. Warboy - 15392 marks - Core i7 920@3890mhz - no description
12. Hondacity - 14916 marks - Core i7 940@4323mhz - no description
13. Linuxfan2000 - 14576 marks - Core i7 950@4519mhz - no description
14. NBF - 14411 marks - Core i7 920@4200mhz - no description
15. lionel57000 - 14357 marks - Core 2 QX6850 (3.00Ghz)@3000mhz - corsair dominator pc2 9136 & iram 12 gb raid0 as hdd
16. aicjofs - 13529 marks - Core 2 QX9650 (3.00Ghz)@4499.20mhz -
17. DR3 - 13235 marks - Core i7 920@4409.90mhz - no description
18. yozuri - 13075 marks - Core 2 QX6700 (2.66Ghz)@4430mhz - no description
19. FatalOne - 12989 marks - Phenom II X4 940@3710mhz - no description
20. HeavyH20 - 12274 marks - Core 2 QX6700 (2.66Ghz)@4350mhz - CPU Phase GPU Air
21. \/\/ater (ooler - 11714 marks - Core 2 QX6800 (2.93Ghz)@4000mhz - no description
22. skinnee - 11339 marks - Core 2 Q9450 (2.67Ghz)@3640mhz - no description
23. chew* - 11258 marks - Phenom II X3 720 BE@4710mhz - no description
24. deachus - 11116 marks - Core 2 Q9450 (2.67Ghz)@3805mhz - no description
25. Vett96wLT4 - 11046 marks - Core 2 QX6700 (2.66Ghz)@3900mhz - no description
26. BoNg - 11014 marks - processor unknown - 3.6 ghz @ 1.4v, 7-7-7-24-28@1.72v, gpu 955/1155
27. J-Bo - 10695 marks - Core 2 Q6600 (2.4Ghz)@4251mhz - Q6600 @ 4251 MHz VapoChill LS 1.72Volts - 2x eVGA 8800 GTXs GXU BIOS 621/1116 on Air
28. TheGoat Eater - 10656 marks - Core 2 E8400 (3.0Ghz)@4500mhz - Rough testing run , edit: the comment on the text doc is wrong when I typed it in - it is 9x multi not 9.5x (thinking of my E8500)
29. aGeoM - 10034 marks - Phenom X4 9500@2800mhz - Phenom X4 9500 @2800 1.45v air cooled, DFI 790FX Bios 307 - G.SKILL F2-6400CL4D HK @510 CL5 5-5-12 2CR Ganged 2.21v
30. MaxCFM - 9961 marks - Xeon E5462@2800mhz - no description
31. PcCI2iminal - 9891 marks - Core 2 QX6700 (2.66Ghz)@3900mhz -
32. riptide - 9764 marks - processor unknown - no description
33. Don_Dan - 9726 marks - Core 2 E8600 (3.33Ghz)@4400mhz - no description
34. illuminati-hwt - 9556 marks - Core 2 E6600 (2.4Ghz)@3822mhz - Watercooled
35. daemon - 9294 marks - Core 2 E6600 (2.4Ghz)@3998mhz -
36. ChaosMinionX - 9249 marks - Xeon 3060@3600mhz - Xeon 3060 @ 3600Mhz - 1900XTX
37. RivalNeighbour - 9010 marks - Core 2 E6600 (2.4Ghz)@3411mhz - E6600 @ 3411Mhz evga 8800gtx @ 575/900
38. mr_knowitall15 - 8967 marks - Core 2 E6600 (2.4Ghz)@3465mhz - no description
39. Quest For Speed - 8965 marks - Core 2 E6600 (2.4Ghz)@3600mhz - E6600 @ 3600Mhz - X850XT
40. stestan - 8832 marks - Core 2 Q6600 (2.4Ghz)@3000mhz - no description
41. Nasgul - 8457 marks - processor unknown - no description
42. jettasin00 - 8285 marks - Core 2 E6400 (2.13Ghz)@3550mhz - no description
43. dangals - 8266 marks - Core 2 Q6600 (2.4Ghz)@3.60mhz - no description
44. DAK1640 - 8109 marks - Core 2 E6600 (2.4Ghz)@3600mhz - E6600 @ 3600 -X1950Pro @ stock
45. mustang9621 - 7743 marks - Opteron 185 90nm@2957mhz - no description
46. [MadMan] - 7713 marks - Athlon 64 5200+ X2 Windsor@3406mhz - Windsor F3, Corsair cheap ram, OCed 8600GT and 36G raptor
47. dsl - 6822 marks - Opteron 175 90nm@2805mhz - no description
48. Genius_pt - 6359 marks - Pentium 4 'D' 945@4343mhz - no description
49. Druggedpolak - 6325 marks - Athlon 64 4000+ X2 Windsor@2850mhz - am2 x2 4000 @ 2.85 and 1800xt @ 670 /792
50. talonz - 6260 marks - Opteron 165 90nm@2712mhz - no description
51. SparkyJJO - 6257 marks - Opteron 165 90nm@2810mhz - Asus A8R32-MVP, 2GB G.Skill PC3200
52. rvd - 6170 marks - Core 2 E6600 (2.4Ghz)@3420mhz - no description
53. Dutch-Patriot - 6004 marks - Opteron 165 90nm@2700mhz - no description
54. MAXakaWIZARD - 4598 marks - Core 2 T5600 (1.83Ghz)@1829mhz - no description
55. Magnj - 4041 marks - Athlon 64 3500+ Clawhammer@2551mhz -
56. Kemo6600 - 3700 marks - Athlon 64 3200+ Venice s939@2608mhz - 133 ATA HD
57. jimwah - 3682 marks - Athlon 64 3200+ Clawhammer@2200mhz -
58. -Acid- - 3434 marks - Athlon 64 3000+ Newcastle s754@2512.70mhz - no description
59. pattertj - 3110 marks - Core T2400 (1.83Ghz)@1829.40mhz - no description
60. LostInSpace278 - 2915 marks - Athlon XP-M 2600+@2505mhz - no description
61. raccoonone - 2846 marks - Athlon XP 2800+@2140mhz - no description
62. MarioMaster - 2377 marks - Athlon XP 2500+ Barton@2088mhz - no description
63. Jaivan - 2108 marks - Atom N270@2000mhz - no description
64. Sublimis - 2039 marks - Sempron 2800+ Palermo@2136mhz - AMD Sempron 2800+ (1600 MHz Palermo) @ 2136 MHz (stock cooler), Gainward GF3Ti200 200/450
65. jspace - 1615 marks - Athlon XP-M 2200+ Barton@2300mhz - My HDD sucks :P
PCMark 2005 Athlon 64 subranking - hall of fame - performance statistics - more
PCMark 2005 Athlon 64 X2 subranking - hall of fame - performance statistics - more
- 1. Alex@Lion (Overclockers.com.UA Team) - 11455.00 - no description
2. Turrican (Team OCX) - 9096.00 - DFI LP UT nf4 Ultra-D, 1Gb Mushkin Redline, I-Ram Raid-0
3. IceCube (Russian Overs Team) - 8175.00 - no description
1. Magnj - 4041 marks - Athlon 64 3500+ Clawhammer@2551mhz -
2. Kemo6600 - 3700 marks - Athlon 64 3200+ Venice s939@2608mhz - 133 ATA HD
3. jimwah - 3682 marks - Athlon 64 3200+ Clawhammer@2200mhz -
4. -Acid- - 3434 marks - Athlon 64 3000+ Newcastle s754@2512.70mhz - no description
5. raccoonone - 2255 marks - Mobile Athlon 64 3200+ Clawhammer@2005mhz - no description
PCMark 2005 Athlon XP subranking - hall of fame - performance statistics - more
- 1. Alex@Lion (Overclockers.com.UA Team) - 15727.00 - no description
2. cucuit-TXPC (Overclocking Argentina OC Team) - 14698.00 - run on i-ram
3. Turrican (Team OCX) - 12835.00 - DFI Lp Ut 790FX-M2R, 2GB G.skill 2GBHZ, I-Ram Raid 0
1. aGeoM - 8691 marks - Athlon 64 5600+ X2@3472mhz - Athlon64 X2 5600+ @3472 1.65v water cooled, ASUS CROSSHAIR II Formula, Bios 0502 - G.Skill 2*1Gb F2-6400CL4D HK@579 CL5 5-4-6 2CR 2.32v
2. [MadMan] - 7713 marks - Athlon 64 5200+ X2 Windsor@3406mhz - Windsor F3, Corsair cheap ram, OCed 8600GT and 36G raptor
3. FatalOne - 7491 marks - Athlon 64 6400+ X2@3440mhz - no description
4. aicjofs - 7226 marks - Athlon 64 4200+ X2 Manchester@2781mhz - no description
5. Druggedpolak - 6325 marks - Athlon 64 4000+ X2 Windsor@2850mhz - am2 x2 4000 @ 2.85 and 1800xt @ 670 /792
PCMark 2005 Atom subranking - hall of fame - performance statistics - more
- 1. AndreyKV (Russian Overs Team) - 5053.00 - no description
2. phill (Bench Tec UK) - 4329.00 - A special thanks to Dave (Blinditter) for the loan of the ACard!!
3. Turrican (Team OCX) - 4014.00 - Abit NF7-S Rev. 2.0, 2x 256MB Mushkin PC3500 Level II "BH-5", 2-Stage Cascade .
2. TheGoat Eater - 2803 marks - Athlon XP 3200+@2205mhz - PALIT AGP 7300GT used in this baseline test
3. MarioMaster - 2377 marks - Athlon XP 2500+ Barton@2088mhz - no description
PCMark 2005 Core 2 Duo subranking - hall of fame - performance statistics - more
- 1. xt0m (Bright Side of Overclocking*) - 3760.00 - Zotac Ion (with Atom 330) barebone + 120mm extra fan
2. turionX (www.EasyCOM.com.ua) - 3288.00 - no description
3. CQSTELUSH (CO2 SOLiD) - 3103.00 - Intel Atom 330, overclocked to 2108 MHz and paired with a Corsair CM2X1024-6400C5DHX memory kit, on the ASRock NetTop ION based.
1. Jaivan - 2108 marks - Atom N270@2000mhz - no description
2. Linuxfan2000 - 1612 marks - Atom N280@1694mhz - no description
3. Genius_pt - 1535 marks - Atom N280@1961mhz - no description
PCMark 2005 Core 2 Extreme subranking - hall of fame - performance statistics - more
- 1. jabski (Bench Tec UK) - 27303.00 - no description
2. Stelaras (H.O.T.) - 26646.00 - Core 2 E8600 @ 5900mhz / GTX280 @ 715/1265Mhz
3. team hardwaretest (PcTuner.net OC Team) - 26546.00 - E8600@ 6000 mhz on Cascade -3 x iRAM RAID 0 ICH10R - Nvidia 260 GTX SOFT VOLT MOD AIR - CSX , PC16000 DIABLO DDR3 1926Mhz- 8-7-6-18-1T - Rampage Extreme, Fabbry Benmaster TEAM HARDWARETEST!!
1. mkultra - 13317 marks - Core 2 E8400 (3.0Ghz)@3970mhz - no description
2. Hondacity - 12616 marks - Core 2 E8600 (3.33Ghz)@5000mhz - no description
3. lionel57000 - 12003 marks - Core 2 E6700 (2.66Ghz)@3200mhz - no description
4. NBF - 10890 marks - Core 2 E7200 (2.53Ghz)@4112mhz -
5. TheGoat Eater - 10656 marks - Core 2 E8400 (3.0Ghz)@4500mhz - Rough testing run , edit: the comment on the text doc is wrong when I typed it in - it is 9x multi not 9.5x (thinking of my E8500)
6. Don_Dan - 9726 marks - Core 2 E8600 (3.33Ghz)@4400mhz - no description
7. yozuri - 9569 marks - Core 2 E6600 (2.4Ghz)@3750mhz - no description
8. illuminati-hwt - 9556 marks - Core 2 E6600 (2.4Ghz)@3822mhz - Watercooled
9. daemon - 9294 marks - Core 2 E6600 (2.4Ghz)@3998mhz -
10. riptide - 9012 marks - Core 2 E6600 (2.4Ghz)@3735mhz - no description
11. RivalNeighbour - 9010 marks - Core 2 E6600 (2.4Ghz)@3411mhz - E6600 @ 3411Mhz evga 8800gtx @ 575/900
12. mr_knowitall15 - 8967 marks - Core 2 E6600 (2.4Ghz)@3465mhz - no description
13. Quest For Speed - 8965 marks - Core 2 E6600 (2.4Ghz)@3600mhz - E6600 @ 3600Mhz - X850XT
14. jettasin00 - 8285 marks - Core 2 E6400 (2.13Ghz)@3550mhz - no description
15. DAK1640 - 8109 marks - Core 2 E6600 (2.4Ghz)@3600mhz - E6600 @ 3600 -X1950Pro @ stock
16. rvd - 6170 marks - Core 2 E6600 (2.4Ghz)@3420mhz - no description
PCMark 2005 Core 2 Mobile subranking - hall of fame - performance statistics - more
- 1. hipro5 (H.O.T.) - 30609.00 - Not bad....I'll keep on.... :o)
2. Dinos111 (H.O.T.) - 28646.00 - Test. (Next time, Cpu & Vga under LN2)
3. Gomeler (PURE) - 28101.00 - Awesome QX9650/Gigabyte X48T-DQ6/Corsair 1800C7 Dominator/EVGA GTX280/Corsair HX1000 5555MHz @ 1.84v @ -104C Thanks Corsair for the DDR3, PSU, and VGA!
1. FUGGER - 21097 marks - Core 2 QX6850 (3.00Ghz)@4849mhz - QX6850 @ 4849MHz - 8800U @ 750/1250
2. sson74 - 15661 marks - Core 2 X6800 (2.93Ghz)@4920mhz - no description
3. Francis69007 - 14388 marks - Core 2 QX9650 (3.00Ghz)@4400mhz - no description
4. lionel57000 - 14357 marks - Core 2 QX6850 (3.00Ghz)@3000mhz - corsair dominator pc2 9136 & iram 12 gb raid0 as hdd
5. aicjofs - 13529 marks - Core 2 QX9650 (3.00Ghz)@4499.20mhz -
6. yozuri - 13075 marks - Core 2 QX6700 (2.66Ghz)@4430mhz - no description
7. Linuxfan2000 - 12987 marks - Core 2 QX6850 (3.00Ghz)@3960mhz - no description
8. HeavyH20 - 12274 marks - Core 2 QX6700 (2.66Ghz)@4350mhz - CPU Phase GPU Air
9. \/\/ater (ooler - 11714 marks - Core 2 QX6800 (2.93Ghz)@4000mhz - no description
10. Vett96wLT4 - 11046 marks - Core 2 QX6700 (2.66Ghz)@3900mhz - no description
11. PcCI2iminal - 9891 marks - Core 2 QX6700 (2.66Ghz)@3900mhz -
PCMark 2005 Core 2 Quad subranking - hall of fame - performance statistics - more
- 1. Gamer (Madshrimps Belgium OC Team) - 13316.00 - no description
2. katiephil (Bench Tec UK) - 12985.00 - no description
1. Don_Dan - 5980 marks - Core 2 P8700 (2.53Ghz)@2532.70mhz - Asus N90SV-UZ022C
2. Genius_pt - 5792 marks - Core 2 T9400 (2.53Ghz)@2527mhz - no description
3. loonym - 4750 marks - Core 2 T6670 (2.2Ghz)@2194mhz - no description
5. Linuxfan - 4524 marks - Core 2 T5270 (1.40Ghz)@1596mhz - OCZ Vertex 120GB SSD=fast dell laptop!
6. pattertj - 3110 marks - Core T2400 (1.83Ghz)@1829.40mhz - no description
7. NBF - 3042 marks - Core T2310 (1.46Ghz)@1446mhz - no description
8. talonz - 2876 marks - Core L2400 (1.66Ghz) - no description
PCMark 2005 Core i7 subranking - hall of fame - performance statistics - more
- 1. KanGaXx - KEW Team (PcTuner.net OC Team) - 25325.00 - ACARD ANS-9010 only ,
2. Evocarlos (Bench Tec UK) - 25080.00 - no description
3. scooter.jay (Bench Tec UK) - 24447.00 - Acard ans9010 raid0
1. Jor3llBR/Elano - 23758 marks - Core 2 Q9650 (3Ghz)@4930mhz - no description
2. pedrorocha - 19562 marks - Core 2 Q6700 (2.66Ghz)@4600mhz - no description
3. Linuxfan2000 - 13982 marks - Core 2 Q9650 (3Ghz)@4518mhz - no description
4. NBF - 13125 marks - Core 2 Q6600 (2.4Ghz)@3840mhz - Whatch out Gomeler, just 15K to go! lol
5. yozuri - 12522 marks - Core 2 Q6600 (2.4Ghz)@4200mhz - no description
6. loonym - 11853 marks - Core 2 Q9650 (3Ghz)@4284mhz - no description
7. skinnee - 11339 marks - Core 2 Q9450 (2.67Ghz)@3640mhz - no description
8. deachus - 11116 marks - Core 2 Q9450 (2.67Ghz)@3805mhz - no description
9. J-Bo - 10695 marks - Core 2 Q6600 (2.4Ghz)@4251mhz - Q6600 @ 4251 MHz VapoChill LS 1.72Volts - 2x eVGA 8800 GTXs GXU BIOS 621/1116 on Air
10. Don_Dan - 9010 marks - Core 2 Q9300 (2.5Ghz)@2587.50mhz - no description
11. stestan - 8832 marks - Core 2 Q6600 (2.4Ghz)@3000mhz - no description
12. dangals - 8266 marks - Core 2 Q6600 (2.4Ghz)@3.60mhz - no description
PCMark 2005 Opteron 90nm subranking - hall of fame - performance statistics - more
2. mtech (Team MXS ModLabs.net) - 29079.00 - Core i7 920 D0@4802MHz 1.4625V cooled with single stage; Asus P6TWS Pro X58 bios0603, PCI-E=109MHz, NB=4574MHz; 3Gb Kingston (Samsung chips)@2287MHz 8-9-8-20-1T, Leadtek GeForce GTX 280@810(1674)/1380 watercooled, 3xGigabyte I-RAM RAID0@ICH10R
3. Aristidis (H.O.T.) - 27579.00 - no description
2. Linuxfan - 19754 marks - Core i7 920@4503mhz - Single OCZ Vertex... RAID 0 coming soon!
3. loonym - 15535 marks - Core i7 920@4203mhz - no description
4. Warboy - 15392 marks - Core i7 920@3890mhz - no description
5. Hondacity - 14916 marks - Core i7 940@4323mhz - no description
6. Linuxfan2000 - 14576 marks - Core i7 950@4519mhz - no description
7. NBF - 14411 marks - Core i7 920@4200mhz - no description
8. DR3 - 13235 marks - Core i7 920@4409.90mhz - no description
PCMark 2005 Pentium 4 s478 subranking - hall of fame - performance statistics - more
- 1. PowerToTheUsers (Madshrimps Belgium OC Team) - 12740.00 - no description
2. Turrican (Team OCX) - 12092.00 - DFI LP UT nF4 Ultra-D, 1GB Mushkin Redline, Single Stage, I-Ram Raid-0,
3. scooter.jay (Bench Tec UK) - 11377.00 - no description
1. mustang9621 - 7743 marks - Opteron 185 90nm@2957mhz - no description
2. aicjofs - 7247 marks - Opteron 165 90nm@3127mhz - no description
3. dsl - 6822 marks - Opteron 175 90nm@2805mhz - no description
4. talonz - 6260 marks - Opteron 165 90nm@2712mhz - no description
5. SparkyJJO - 6257 marks - Opteron 165 90nm@2810mhz - Asus A8R32-MVP, 2GB G.Skill PC3200
6. Dutch-Patriot - 6004 marks - Opteron 165 90nm@2700mhz - no description
PCMark 2005 Xeon subranking - hall of fame - performance statistics - more
- 1. leeghoofd (Madshrimps Belgium OC Team) - 7393.00 - no description
2. George_o/c (H.O.T.) - 7105.00 - P4 3GHz @ 4155MHz @ 1.825Vcore | Asus P4P800-E Deluxe (un-modded :-() | OCZ PC4000 VX 1GB 250MHz @ 277MHz 3-3-3-8 @ 2.85Vmem (not optimized at all) | X1650 @ 641/535 MHz ... easy ... :p (Why can't I change the memory rating, it's PC4000 and not PC2700
3. AndreyKV (Russian Overs Team) - 6886.00 - no description
1. lionel57000 - 4069 marks - Pentium 4 3.2Ghz EE - no description
2. aicjofs - 3485 marks - Pentium 4 3.2Ghz Northwood@3501mhz - no description
3. Don_Dan - 1841 marks - Pentium 4 2.66Ghz@2659.20mhz - no description
- 1. AndreYang (PURE) - 31292.00 - 1*Acard and OCZ SSD tested. GA mobo is good for PC mark05.
2. team hardwaretest (PcTuner.net OC Team) - 29390.00 - Xeon w3540@ 5139 on Ln2 - Corsair Dominator GT PC 15000 7-7-6-18-1T - Evga Classified - Asus 4890 - ACARD 9010 Testing - Windows 7 testing - Fabbry-Benmaster, TEAM HARDWARETEST!!,Thanks: PcTuner Forum for the support.
3. MaJ0r (XtremeLabs.org) - 27473.00 - Xeon w3540, Gigabyte EX58EXtreme, 2 Gigabyte I-RAM RAID 0 on ICHR10
1. loonym - 24902 marks - Xeon W3520@4470mhz - no description
2. mkultra - 21578 marks - Xeon W3520@4524mhz - no description
3. Warboy - 13227 marks - Xeon X3360@3825mhz - no description
4. ChaosMinionX - 9249 marks - Xeon 3060@3600mhz - Xeon 3060 @ 3600Mhz - 1900XTX
generated by hwbot - http://www.hwbot.org - info@hwbot.org
