has anyone used this ? problems?
If possible I wanna use this on a mac book pro
While I personally have all of about 15 minutes experience with it, my brother is into DJ'ing and has used Final Scratch since Stanton came out with it, although he is using it under windows I'm sure it's very comparable on either system. It has almsot 0 delay issues, it makes beat matching a snap, and que'ing up songs is crazy easy. He very much enjoy's it and loves that he doesn't have to cart 80 pounds of records out to gig's. Basically take a gander at the reviews, the new final scratch is bete then ever..the product really does live up to it's hype.
E6300+Biostar TforceP965 express=3.4ghz(480x7)
Final Scratch isn't compatible with the intel macs, just that you know!
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
ah thats what I was hoping to use it with.. thanks
I wiki'd it and it said it had problems.
