we all been there...
all checking out some product and wanted to see what someone thought of it, and read something so incredibly dumb or misinformed that you wanna write to newegg of why they need to remove that reviews "thoughts" cause all they are doing, is spreading misinformation and half ass opinions.
so...
how about we find them, and post them?
theres thousands there, whats the worst ones you can find??
post them, and give a small reason of whats wrong with it.
from the P5B-E...Cons: There have been many memory problems DDR-2 memory. This is NOT the fault of the chipset manufacturer (intel, nvidia) but rather the fault of the memory manufacturers. JEDEC standards call for all DDR2 memory DIMMS to run at 1.8v. If a memory DIMM needs 2.1v to run at DDR2-800, it wont boot in a lot of systems. Luckily, motherboard and chipset manufacturers have built safeguards into their systems (Like this motherboard). Memory manufacturers have also started creating better SPD settings and they have also started to have good enough memory yields to produce DDR2-800 memory modules that can run at 1.8v. My G.Skill memory I bought runs at 1.8v-2.0v which is most likely NOT JEDEC-Approved but it worked fine in this motherboard. It appears that this motherboard will support memories with non-standard SPD settings but I may be wrong. I have not had any other major problems with this motherboard so far.
whats wrong??
ram is not programmed to boot at a specific voltage.
just like if you put some OCZ VX4000 in your PC its not gonna boot at 3.5 volts...
what happens is, ram has a safe boot speed, so it should boot in any board, at 1.8 volts or so...
typical boot settings for DDR800 is usually 667 mhz, cas 5-5-5...
does this mean somethings wrong with the ram?
absolutly not.
it means, you have to go into the bios and set the mhz/voltage manually and the cas too.
this person Quotes JEDEC, so he sounds like he knows what he's talking about, but you can tell its a combination of quoting reviews and such that he didnt really bother to read... and trying to make himself look smart, cause he heard the word JEDEC....
