+ Reply to Thread
Results 1 to 5 of 5
Thread: Compact gpu cooler
    Xtreme Member The Weedman's Avatar
    Feb 2005
    Ontario, Canada
    0
    Compact gpu cooler
    I have the day off today and i am bored so i decided to use this 1/6hp comp i have laying around and build a gpu cooler.
    Its not the best looking but i put it together in 3 hours including vac and charge. And before anyone says anything i know the condensor is overkill but its all i have here so it will have to do.
    The total dimensions are 10" wide x 12" long x 8" high. Im using a chilly1 evap with the provided gpu mounting.
    This temp is unloaded until i insulate the 6800gt i plan to freeze or rather attempt to remove the massive stock cooler from it.
    I will update once i get some load temps and clocks.
    AMD PII 1090t
    Patriot 1600mhz 2x2gb
    Asus Crosshair IV
    Corsair HX1000
    PC 5870 1gb
    2x HAF932 Welded together
    Cooling: Cpu Loop
    Pa120.3 w\ 3x Scythe GT
    Dtek Fusion V2
    Mcp 655
    Ek 150 w\ 2 bottoms w\1 troy oz silver
    DD brass fillport
    Primochill Pro Lrt Black/Red tubing
    Cooling: Gpu Loop
    Mcr 320 w\ 3x Scythe GT
    Swiftech mcw80 w/switech fc heatsink
    Mcp655
    DD fillport
    -100c Club Member LittleDevil's Avatar
    Dec 2004
    Europe
    1
    Looks good
    thanks
    My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LN² Pots, LD GFX-R1 Dice/LN² Pots,
    LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
    LD PC-V8 Watercooling Cases:
    LINK
    LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
    www.ldcooling.com
    Find US on Facebook
    Oct 2006
    California, USA
    0
    Nice!
    Feb 2005
    Ontario, Canada
    0
    I cant even hear it over the 12v fan.
    AMD PII 1090t
    Asus Crosshair IV
    Corsair HX1000
    PC 5870 1gb
    Cooling: Cpu Loop
    Dtek Fusion V2
    Mcp 655
    DD brass fillport
    Cooling: Gpu Loop
    Mcp655
    DD fillport
+ Reply to Thread
