i've been overclocking my new rig and seem to have run into a wall at 401x9. i tried more volts but just can't get any more mhz's out of it. do i need to increase the volts to the chipset?
Asus P5W DH E6600 400x9*3.6 1.55v CORAIR PC8500 XFX 7800GTX OC Asetek Pump-DangerDen TDX Coolmax 600w
Yes you do. The higher you push The FSB the more you need to increase your V.much
Asus P5B Deluxe ~ E6700 @ 3.6 360x10 / 1.35v ~ Swiftech Water
2x1Gb Crucial Ballistix 4-4-4-4 1:1 ~ Evga 8800GTX
WD Raptor 2x74gb(Raid0) ~ OCZ GX 600w ~ Lian Li V1000B
Read this thread, e6600 3.7ghz on a p5w-dh
http://www.xtremesystems.org/forums/...d.php?t=115037
i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
Asus P8P67 Vanilla
Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
Diamond HD 7970
WD 600GB Velociraptor
Corsair TX750W
CM 690 II Advanced
Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
thanks for the replies... i brought the vmch up one notch and now i'm at 414x9*3.72 with 1.65v, what about the ich what would be the best settings... i'm not to sure about raising it
