+ Reply to Thread
Results 1 to 5 of 5
Thread: KX7 beats NF7-S 2.0 in single channel!
    Jul 2002
    UK
    0
    KX7 at 200fsb on maxed timings and normal cpu decode scored 1221/1315 in sandras unbuffered test. Thats 2/5/2 cas2, 1t, enhance on.
    NF7-S 2.0 at 200fsb, 5/2/2/2 scores 1158/1257 with the same cpu speed.
    NF7-S 2.0 on maxed timings and 222fsb scores 1278/1407.
    so the KX7 beats the NF7-S significantly in the single channel tests!!
    Registered User threadpooper's Avatar
    Feb 2003
    U S A
    0
    isnt that inside the margin of error?
    could be several variables...which drivers/bios/etc
    Please be more descriptive so we can get an idea of exactly how the test was performed with all variables mentioned
    w00t .... =/
    Sep 2002
    Melbourne, Australia
    0
    If you turn the onboard sound and NIC off, you will get a fair bit better score.
    F@H boxen 39,869 MHz - Standford stats - EOC stats - Folding 4000 Club
    Dugu 9 Tweaks: 3DMark 2001 guides || RAM timings || Recommended RAM settings for P4 DC DDR system || How-to: Overclocking Athlon64
    My PC: A64 3200+ :: Shuttle AN50R :: 2x256MB XMSX3500 @ 270Mhz 2.5-2-2-6 3.4V& 512MB XMS3200LL @ 245MHz 2-2-2-6 3.1V :: Excalibur HIS 9800Pro 128MB :: CMV CT-722D 17inLCD :: 3DMark 2001: 24515 || Watercooling coming "real soon now"...
    Jul 2002
    UK
    0
    errrm why? that stuffs all controlled by the southbridge which has nothing to do with memory?
    the sound and firewire is off anyway only the nic is on.
    inside the margin of error? for an unbuffered test thats a huge difference. they were obviously both run under as close to same conditions as possible using the same o/s and programs, same cpu, same cpu speed.
    Xtreme Member Dr. Possum's Avatar
    Apr 2003
    0
    Interesting...
    ~DP
+ Reply to Thread
