X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: [Denny]XFX7900GS review,
    i should post those like about a month ago but i never had chance to post it...
    i did some quick test like test with E6600 @ 3G but thats it.
    here is better review for 193$ (i bought from mwave)
    1.4ns hynix GDDR3
    i really love those black pcb! looks great...
    Hardware setup
    Intel C2D X6800 @ 3.9G 434*9
    Asus P5WDG2 WS PRO 改
    GSKILL DDR2 800 CL3 2GBGA
    XFX 7900GS SLi
    PC Power & Cooling 1000W
    TQ120
    7900GS is running on Stock speed
    3dmark2001 score 57972
    3dmark03 score 32662
    3dmark05 score 14169
    3dmark06 score 7827
    Overclock to 630 / 850
    3dmark2001 score 65059
    3dmark03 score 41998
    3dmark05 score 18978
    3dmark06 score 10422
    although GTO is like ~250$ but 7900GS only ~193
    but while the profromance is very close to each other.
    also the 1.4ns 1.9v hynix does better overclock than 1.1ns 1.9v samsung....
    ~60$ maybe doesn't mean a lot to some ppl, but who know hehehehe
    Denny @ 10/10/06 and Happy B-day to Taiwan, ROC
    May 2006
    Philippines ^_^
    wow!!! nice result man.. I like your setup.. and the color matches..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    lol no one love my thread hahahahah
    but since it is G71 core!! i should let it runs as 7900GTX!!!!!
    after using pencil drew everywhere.... it becomes like 740~750... weird lol
    3Dmark03
    3Dmark05
    3Dmark06
    still with stock heatsink...
    hot hot...
    Jan 2005
    Ioannina
    Awesome clocks and $/performance ratio !!!!! Can u post card drawings or send it via pm / ?
    May 2003
    There is a pencil mod for th VGPU?
    And awesome clocks for budget cards. For cheaper than an X1950XT you're getting way better performance with less heat.
    May 2003
    Hopatcong, NJ
    very nice clocks. These are great bang/buck cards if you get ones that don't die/artifact.
    As far as mods, the same 7900GT mods can be applied. Conductive Pen makes an easy vcore mod
    'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
    'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
    'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
    Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
    HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
    thx to T024484 his mod!!! i copy it from him!!
    http://www.xtremesystems.org/forums/...ad.php?t=94177
    and please check the page 22, 531
    i did the 1.4v mod! the purple one! the very last row
    Apr 2005
    Germany, Bremen
    ohh, nice test today i've got my two Gainward 7900GS. and my systems is nearly the same like yours.
    i hope i have no problems...
    Xtreme Cruncher
    Nov 2005
    Netherlands
    I like these kind of bang for your buck reviews. Thanks.
    Oct 2005
    Very impressive scores denny, I almost want to get two to play with
    Nov 2005
    http://service.futuremark.com/compare?3dm06=542168
    I finally cracked 6k with my single card on my lowly e6300es with my crappy generic ddr2 :P These are great cards Stock hs/f too.
    Mar 2006
    Hello,
    What kind of mod did you do?
    Can you tell me how the 7900gs vMod works?
    I don't understand it =(
    Where did you draw?
    What Watercooler fits with the 7900gs?
    Could you test single 7900gs with conroe @ 2000 or 2400?
    Thanks!
    Best Regards
    Dennis
    Quote Originally Posted by bl1zZ
    Hello,
    Where did you draw?
    Thanks!
    Best Regards
    Dennis
    there is a very detail pic and description on the page 22, post 531
    please read it so you have more idea how to mod
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    looks like a nice midrange card to me
    Quote Originally Posted by charlie
    the new X1900GT ver.2 is great too......
    Jan 2006
    Quote Originally Posted by guess2098
    actually im hearing ati tool cant raise voltages for it.
    Asus p5n-e sli
    E6300 stock heatsink
    2 x 1 ddr667 supertalent 5-5-5-13 2.1
    X1800xt 256mb
    Enermax liberty 620
  18. #18
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    have you tried upping volts via biosmod? what was stock volts for your card?
    im finding raising volts via biosmod results in lower OC even with temps under 40c load.
    is yours the 480m or 450m?
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
  19. #19
    Mar 2006
    Ah ok, now i understand
    What kind of pencil can i use for that mod? (there are different onn the market)
    I have to connect all 3 purple marked things, or?
    Do you know, which watercooler fits on this card?
    Could you do runs with 2000mhz and 2400mhz on the cpu with a single card?
    Best Regards
    Dennis
    PS: Whats stock core voltage?
    And sorry for my bad english -.-
  20. #20
    Quote Originally Posted by WeStSiDePLaYa
    the stock voltage is 1.2v, it is set on bios. change volt in bios will not help
    Best Regards
    Dennis
    2B pencil, i don;t have watercooling so....
    conroe 2G or 2.4G... i think it is too low...... probably like 9000 on 05 for one card
  21. #21
    Feb 2005
    Italy
    nice vgas m8!!!
    is it the max they can do?
    Marco
    XtremeHardware.it
    Asrock Italian Official Support Forum, Enermax and Sapphire Support Forum
  22. #22
    Apr 2005
    Germany, Bremen
    My new cards...
  23. #23
    Aug 2006
    oh~~nice card nice work
    AMD ATHLON 3000+ 512+512+256+256 KINGSTON DDR400 RAM +EPOX NF4 SLI+ SEAGATE 160G
  24. #24
    May 2006
    Belgium
    Very nice results guess2098.
    About match my results with 7900GT SLI (vmodded 1.5V), but with 4 pipes less : impressive !!
    I also did a review by the way of this card for Madshrimps, but wasn't allowed to vmod it at the time
    "The light at the end of the tunnel is the headlight of an oncoming train" (Murphy)
    Reviewing for Madshrimps
  25. #25
    Apr 2005
    Germany, Bremen
    Could you bench AQ3?
    My SLI-Score:
    SeLecT - 188488 - 21243 - 313867 - C2D E6600@3753Mhz - 2*1024MB Cellshock DDR2-834 @ 4-4-4-12 - Gainward 7900GS SLI 546/799
