Results 1 to 9 of 9
Thread: Mushkin HP5300 on P5W64
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Trying out these Mushkin HP series PC5300 sticks...
    Quite nice in the $200 price range. I'm starting to see more and more $450 sets of sticks so a set at half the price is refreshing. They appear to run fine up to about 490-500 @ 4-5-4 and a bit above 510-520 at 5-5-4. This works well enough for gaming and "non xtreme usage".
    When I get my P5B Dlx back from RMA I'll try these in there...
    Mushkin HP5300 2 x 1gB
    Asus P5W64
    Mushkin XP650 PSU (bulletproof)
    X800
    Thermalright Ultra 90
    Oct 2002
    Field of Battle
    1:1 I was held back by the low FSB ability of this P5W64, 420ish...
    With an E6600 or 6700 this'd be nice for 3.8gHz 24/7...
    Oct 2002
    Field of Battle
    Nice bandwidth for loose timings and only 505.
    version 2.0
    Feb 2005
    Flanders
    any idea what IC's are on these sticks? Elpida maybe?
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    try cas 5-4-4-10 or close.
    cas 4 doesn't mean much to me personally, but ras to cas 4 is a must for me...
    Jan 2006
    what's your voltage at 418fsb?
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by Jaco
    The ones i have are elpedia
    They work well for what they are, i got the 512x2 for 22 A/R from newegg when there wasnt a memory shortage.
    your money is in better hands with micron for ~50-75 dollars more
    CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Zippy 700W (fan modded of course)
    Oct 2002
    Field of Battle
    I suspect elpida also...
    Kunaak, ras to cas 4 is ok, just costs a few mHz worth of OC. Right now I'm gaming on it at 405 1:1, 4-4-4 on 975x.
    For the $$ it's just fine.
    Oct 2002
    Field of Battle
    Quote Originally Posted by exhausted mule
    I've tried from 2.1-2.4v and don't notice much of a difference.
