I have a set of 2GB Patriot PC2-5300 DDR2 667Mhz RAM, along with a slighly overlocked E6600 (running at 320x9 = 2.88Ghz)
Right now, I pushed the voltage up to 2.0V, and I'm running 800Mhz at 4-4-4-10 stable.
Earlier, when I tried 4-3-3-8 in MemTest86+, there were a lot of errors piling up immediatly from the start. Now however, lowest Itried 4-4-3-3 in MemTest86+ and no errors were showing up from the start, I didn't run the test for long, because I'm not sure about those timings.
My main question is, can RAM be damaged from lowering timings? I know pushing up the voltage can, but I'm only running them at 2.0V.
My second question is, say these sticks do pass MemTest86+ at 4-4-3-3 timings for say, 5 hours - does that mean they are always stable (refferring back to when I got error at 4-3-3-8 timings at the same speed and voltage) Is it possible that the command rate was changed from 1T to 2T by Auto, making 4-3-3-3 timings work?
Third question... Why do only my first 4 timings show up in CPU-Z? And where do I set the command rate in the BIOS (Gigabyte DS3 F6)?
Thanks in advance.
